F22 stroker from F20 confirmation please
Hi,
I have a JDM AP1 F20, and from what I have gathered to convert it to 2.2, I just used the AP2 crank and rods and use the AP1 pistons. And that using the JDM pistons means the static compression ratio rises to 12.7:1? Is that correct? No change of oil pump or block modifications?
Im assuming with a decent tune and fuel around 210-220WHP is achievable?
Cheers!
Andrew
Cheers!
Andrew
So you just used the F22 crank and rods, no other tricks to this conversion? Sounds pretty straight forward! Did you dyno it?
Originally Posted by dagle' timestamp='1391201973' post='22993087
I cannot comment on the static compression ratio since I didn't do the math on it, but I have the exact setup you described. It runs on 91 Octane perfectly fine on an 2000 or 2004 ECU.
Originally Posted by AE85' timestamp='1391202515' post='22993104
[quote name='dagle' timestamp='1391201973' post='22993087']
[/quote]
Yeah I imagine the extra compression is not substantial.
I dont think we have an AP1 F22 here, we only have an AP2 F22, Im assuming either crank and rod from AP1 or AP2 will work in the F20C1?
I'm doing the same thing.
My engine is a F20C, and i bought the f22c crower rods, and still searching for a f22c crank for a good price, but it is a direct fit
Unfortenately we dont have the f22c here in Europe.
Why didnt you just use the stock rods out of interest? Im looking for a reasonably priced crank too! Inline Pro has stock used ones for $750! Bit much for me...
I wanted to buy the custom ones from Urge Designs, but not being my car a only a race car, only for some trackdays, i decided to buy the normal crower set. I think the diference is on the bolts.
Good to know Inline Pro have used ones for sale, i need one urgent =) but they are still expensive for used cranks..
