How I rebuilt my Paxton Novi 1000
Old Dec 3, 2014 | 04:30 AM
E4RTH WORM JIM's Avatar
Default How I rebuilt my Paxton Novi 1000
I promised a couple of members on the board that I would write a summary of how I built my Novi 1000.
This is not a HOW TO! it's simply some pictures and information on how I did mine so please be aware this may not be the correct procedure.
I thought mine sounded loud so I wanted to change the bearings, hence why I rebuilt it.
First I removed the supercharger from the mounting plate:
Removed the pulley and washer:
Then I removed all the allen key cap head bolts holding the rear casing on:
View of inside:
I removed the three spring washers and two spacing washers form the output shaft bearing. I placed these in the insert in the housing plate for safe keeping:
Output shaft bearings:
Input shaft bearings:
Then I lifted the input shaft assembly out:
Removed the spring washer and stored it for safe keeping:
I then flipped the casing over and removed the volute:
Now off I went to my workshop (well my work's workshop:
Picture of parts:
I then placed the casing into a vice (with the output shaft/bearings still attached), heated the impeller with a blow torch then removed the locking nut and impeller. once you remove these the output shaft assembly just pops out:
I melted the old output shaft seal but this was getting replaced anyway:
Then put the washers with the impeller for safe keeping:
I then removed all bearings with bearing pullers
I removed all four bearings and refitted them using a bearing induction heater. If you haven't got a bearing induction heater just heat the bearings in some fresh motor oil to 100'C in an oven!:
WHEN ISTALLING THE NEW BEARINGS MAKE SURE YOU INSTALL THEM IN THE SAME ORINTATION AS REMOVED! NUMBERS FACING OUTWARDS!
I then removed the input & output shaft seal with a press and hand tools:
I then pressed in the new seals - Please note; you can easily damage the seals so please be cautious!!! You need to heat the casing with a blow torch (or this is how Paxton recommend). You must press the output shaft in on the inner race/sleeve ONLY! I used some 17mm round bar for the output shaft. The input shaft can be done by hand
I then laid all the components out and re-assembled:
Once I'd reassembled all the parts within the casing. I installed the rear cover with the allen key bolts. Then placed the input shaft into a vice and clamped it. Heated the impeller with a blow torch and dropped the impeller back onto the output shaft.
Like this:
Then I screwed on the lock nut and tightend.
You can now re-install the impeller, volute and pulley.
I then fitted the charger to the car. I spun the input shaft by hand (with the belt removed), I could hear the impeller touching the volute so I clamped the input shaft with a pair of stilsons and tighten the impeller locking nut. I tightened it to what felt tight to me. Please go careful as you could break the helical gears if excessive force is applied!
I then marked the lock nut with a line to see if it moves - which it hasn't so far.
Old Dec 3, 2014 | 04:31 AM
For information:
I bought the bearings from a UK supplier no problem, they cost my £150
Parts I used:
X2 SKF 6206 C3 bearings
X2 Barden 203H bearings
X1 input shaft seal
X1 output shaft seal - 30mm
Seals can be bought from here:
http://www.superchargerrebuild.com/paxton/
I did purchase a seal from JBO but I didn't like the type of output shaft seal so opted for the OEM type from the above.
Any questions please ask, I typed that lot as quickly as possible
Old Dec 3, 2014 | 04:38 AM
VTEC2000's Avatar
Nice write up. Hows it sound and run?
Old Dec 3, 2014 | 04:45 AM
Great, still sounds noisy though!
I bought mine second hand so didn't know how they was meant to sound.
Old Dec 3, 2014 | 05:04 AM
Krisbuc's Avatar
Cracking write up cheers what was your shopping list for parts needed ?
Old Dec 3, 2014 | 05:06 AM
Soul Coughing's Avatar
Great information! I recently rebuilt my Paxton 1000 as well and my impeller only had one shim on it, compared to two on yours! Seems that there is quite a bit of variation with their builds. Also, from my research, the impeller nut needed 35 ft/lbs, or at least, that's what a paxton manual said. Thanks for the write up!
Old Dec 3, 2014 | 06:57 AM
SeanGPW's Avatar
Great write up! I was thinking of doing this but I found out that I did not have to yet.
Old Dec 3, 2014 | 08:50 AM
s2000Junky's Avatar
Nice write up.
As long as you dont over spin the blowers rated speed, or over tighten the pulley belt, ive seen 150k+ miles on these units before a rebuild was needed. They all sound like a coffee grinder at idle.
Old Dec 3, 2014 | 10:51 AM
Dat956Boi's Avatar
Thanks for the valuable and well placed info OP!
