Expected power - Novi1000 / 3"
Old Apr 21, 2015 | 03:30 PM
amdaman's Avatar
Default Expected power - Novi1000 / 3"
Hi guys,
Before we start I have done a search but the responses vary wildly. I ideally want 400WHP.. is this possible with what I'm planning;
AP1
Novi 1000
3" Pulley
Test pipe
PLM FMIC
AEM 1052U
ACT PP
Fuel will be 98RON from the pump
Also will my standard bosch recirc valve be up to the job?
I know the FMIC will set me back a bit but do you think 400 will be attainable?
Cheers
Old Apr 21, 2015 | 05:39 PM
pwrinxs's Avatar
Curious why Novi 1000 over the Novi 1200? I run the latter with a 4.0 pulley and am around the 400rwhp mark.
Old Apr 21, 2015 | 05:41 PM
amdaman's Avatar
Got the kit used from here. I guess I can always upgrade to the 1200 when this one gives in? Yeah I'm aiming for that sort of figure, I bet that's a hoot.
Old May 12, 2015 | 11:08 PM
amdaman's Avatar
Cool, I've decided to go 2.8" now and it should be tuned by the end of next week. Just put the ACT pressure plate on it ready for the power!
Old May 13, 2015 | 05:06 AM
lude92_si's Avatar
I made 405whp 240tq on my Novi1000 with a 3" id725 walbro 255. At 15psi. Car ran better than stock
Old May 13, 2015 | 01:06 PM
amdaman's Avatar
That's decent, what boost? Did you have a fmic?
Old May 14, 2015 | 08:56 PM
E4RTH WORM JIM's Avatar
From my experience, your looking at 365 ish WHP (UK dyno dynamics)
Old May 14, 2015 | 09:12 PM
s2000Junky's Avatar
Unfortunately an fmic robs you of precious boost which will net you lower then a typical after cooled set up. 3" pulley would normally yield 15psi at 8900rpm/400whp. With a typical fmic set up, you will yield about 12psi and 380whp.
Old May 15, 2015 | 01:49 PM
lude92_si's Avatar
Sorry I was running comptech aftercooler with a big front mount heat exchanger and bigger pump
Old May 15, 2015 | 02:28 PM
amdaman's Avatar
Hmm, hopefully I can get back some of the boost loss with the 2.8" pulley then!
