A Necessary Engine Rebuild
Old 07-26-2015, 06:29 AM
Flipz's Avatar
Default A Necessary Engine Rebuild
So in another thread, some of you may have seen that I managed to spin a rod bearing on cylinder 2 of my pretty much stock F20C AP1. I've already made a start so this first post is just to catch up with where I've got to.
After several months of deliberating what the next step should be, I decided to take the plunge and go for a stroker build, I got some quotes from the likes of TGM but I couldn't warrant the cost, and the plan for my S (when it became promoted to the weekend only car) was to have it as a project to build on over time. So I'm doing all the work myself.
My initial plan was to go for a Brian Crower 2.4 L kit, but I have also been told about the CNC Speedshop kit using the K24 crank, also the Spoon 2.2 stroker kit looked quite appealing. I also quite liked the idea of the KPro 4 EMS (my mate has this on his EP3 and it's a really nice system), but what with all the additional sensors etc. you need for our engines, it would have been a real nightmare.
First job was to remove the engine and check the extent of the damage before making any final decisions on what direction to go in, here's a few pics:
So as you can see, the head is is great shape, no damage at all. The crank is scored beyond repair and the block may get away with just a re-hone, but it's difficult to say - doing the fingernail test, it feels no worse than the others but it does look bad. Still need to measure the diameters and see if/how much ovalling there is to the bores. I forgot to get pics of the pistons, will upload them when I get a chance to snap the pics.
Ordered a crank pulley removal tool so should be able to get that and the timing chain cover off next weekend and see how the main bearings have held up.
Old 07-26-2015, 06:39 AM
Nottm_S2's Avatar
ouch, looks nasty
Old 07-26-2015, 06:55 AM
jayok's Avatar
Love the PICs... best of luck on the venture!
Old 07-26-2015, 12:33 PM
Flipz's Avatar
Originally Posted by Nottm_S2
ouch, looks nasty
It certainly sounded nasty when it went!
Old 07-26-2015, 12:35 PM
Flipz's Avatar
Thanks mate, it's probably going to be slow but should be nice when it's all done.
Old 07-26-2015, 01:41 PM
MB
Member
MB's Avatar
Research very carefully.
Do NOT use Endyn / Urge.
Wadzii at CNC seems very knowledgeable and not heard anything bad about Inline Pro.
But I'd still stick to UK options and someone very experienced with F20 repairs / rebuilds.
Old 07-26-2015, 02:00 PM
Ultra_Nexus's Avatar
Apart from the number 2 cylinder, your bores look good. If it passes the fingernail test I'm pretty sure a re hone will work without issue.
Nice work so far
Old 07-26-2015, 02:03 PM
Nottm_S2's Avatar
Originally Posted by Flipz
Originally Posted by Nottm_S2' timestamp='1437921546' post='23693276
ouch, looks nasty
I hate the sound ofa knocking/rattling engine
Its akin to someone torturing a puppy
Old 07-27-2015, 01:34 AM
mr-pitts's Avatar
Or Kings Performance,if you decide to look for a sleeved block give Bernard a shout at Jjautowerks.
I suspect this is the start of a long list of high milage engines looking to get a rebuild.
Old 07-29-2015, 08:11 PM
eRaceParts's Avatar
Nice Pics man! I like the write up. Totally sucks that it happened, but it's a blessing and a curse...now you have an 'excuse' to buy the other goodies, right? Haha..
Keep up the posts. Will be awesome to see the Spoon motor in with a tune and see what she puts down.
Quick Reply: A Necessary Engine Rebuild
