Removing the Ignition...?
Old Jan 2, 2007 | 11:15 AM
sidecar's Avatar
Default Removing the Ignition...?
Struggling to figure out how to release the ignition from the steering column. The clamp seems to be riveted on. Anyone know how to do this?
Old Jan 2, 2007 | 03:09 PM
Slows2k's Avatar
They are tamper proof bolts. you have to cut them off.
Old Jan 2, 2007 | 03:17 PM
sidecar's Avatar
Damn, I was hoping to tamper with it without the child proof devices getting in the way.
Next question is what is the actual ignition switch? I was easily able to remove all the guts of it... the stuff the key turns. Does the actual ignition body do anything or with it work just by inserting the new guts into another ignition housing that's fried?
Old Jan 2, 2007 | 03:31 PM
Slows2k's Avatar
The electrical part of the ignition switch is separate from the mechanical portion. You can unscrew the switch from the back of the lock cylinder.
TXApex
Jan 18, 2016 10:13 AM
Vanityv3
Jun 29, 2015 04:11 AM
rmk232
Oct 11, 2012 04:52 PM
S2k4mee
Apr 23, 2011 12:34 PM
