TEST PIPE INSTALL
Old Feb 15, 2007 | 07:18 AM
S2kNY's Avatar
Default TEST PIPE INSTALL
I just got a Invidia Test Pipe, how easy is the install? Is it just a few bolts to unscrew or is there something else I should know. I don't want to get any CEL lights to come up. I did buy the extra little O2 bung that's supposed to prevent the CEL will that do the job? Please let me know - thanks
Old Feb 15, 2007 | 07:34 AM
Jql168's Avatar
its really easy, just unbolt the cat and undo the 02 sensor. If you have an older car the bolts may be seized up
Old Feb 15, 2007 | 11:36 AM
s2k dre's Avatar
yup the older the car the worse, i did an invidia on an 03 and the bolts were seized up, just spray some lubricant on the bolts and try to unbolt them.
Old Feb 15, 2007 | 11:43 AM
Enthralled's Avatar
WD40 is your friend.
yeah but the install is easy.just jack the car up and undo the bolts and replace with the TP.pretty straight forward install.
Old Feb 15, 2007 | 12:03 PM
S2kNY's Avatar
thanks guys, one last concern: if I swap back the stock cat when I go to do inspection and then put the test pipe back on right after is there any issues with that?
Old Feb 15, 2007 | 01:49 PM
HiRpmVTEC's Avatar
Ya the car might blow a gasket. J/k Youll be fine
Old Feb 15, 2007 | 05:57 PM
3vilmonkey!'s Avatar
Just get an o2 fix... they don't look under the car. Depending on the state some dont even sniff.
The top bolt was a PITA for me.
Old Feb 15, 2007 | 06:35 PM
gomarlins3's Avatar
Or move to Idaho and live in Kuna where there is NO emissions checks AT ALL!! Lucky me.
Old Feb 16, 2007 | 02:18 AM
CoralDoc's Avatar
Penetrating fluids such as Liquid Wrench and PB Blaster are much better than WD-40 in this application. Apply liberally and let them soak in for as long as possible, then re-apply. When doing work on old, rusty exhaust systems I apply the product, let it sit overnight, and then apply again about an hour before doing the work.
Old Feb 16, 2007 | 04:17 PM
s2kSEOUL's Avatar
This is what the bolts look like. I took pics a day after the install.
Header Side:
Exhaust Side:
The three bolts were HORRIBLE to get off. I snapped one off accidentally but I had new ones from the Invidia exhast I installed at the same time. If you do break a bolt and have replacements you can tap out the old one with a hammer.
This is the O2 before the fix. I can't find a pic with the fix. Before installing the O2 I would suggest pre twisting the sensor in the opposite direction to how you are going to screw it in. It will relieve a little stress on the wire.
