oil cooler install
oil cooler install
Just installed an oil cooler and thought it may be of interest
the bits
2 meters hose
half size oil cooler
temp sensor holder
4 x rubber mounts
2 x 90 degree fittings
2 x 45 degree fittings
due to the front of the rad area being full of other stuff the cooler had to go behind the false vent on drivers side, i made a custom bracket to pick up with an existinghole in the chassis leg and two new holes drilled in the wing stiffening bracket
this is the cooler mounted
to get cold air to the cooler i had to cut out the false grill, i roughed it out using a router blade in the dremel then sanded back to the edge with the rotary sanding drum, the mesh is held in using tie wraps
finished view
i used a thermostat sandwich plate to tap into the oil system, all parts sourced from Merlin Motorsport
things to do different
use a sandwich plate with 4 ports so sensors could be mounted in same area
now i know the exact length of pipe i would get pre made hoses with swaged ends
cooler needs to be further to the left to line up better with the vent hole.
hope it helps, if anybody needs any more details just ask
the bits
2 meters hose
temp sensor holder
4 x rubber mounts
finished view
That's the sort of thing I'll be looking at once I've decided on the next FI step for mine.
I also agree on the need for temp/pressure inputs on the plate too.
be carefull when you buy the plate, mine had a lump on one side where the thermostat valve was housed and this limited the position the pipes could exit
it might be worth looking at a remote filter set up if you can find a spot for the filter
