Soft Top Seam Coming Undone
Old Oct 4, 2008 | 08:09 AM
TheSpeedRacer's Avatar
Default Soft Top Seam Coming Undone
A seam on my soft top is more or less coming undone... it's not really a tear. This is located on the drivers side. Additionally the top did not wont to go down yesterday. It would go back about 3/4 and stop. I guess it's time to make a stop at the dealer.
MY07
16,500 miles
It almost looks like there is a wear mark in this area... the top has a lighter shade here.
Old Oct 4, 2008 | 08:57 AM
S2KAYYY's Avatar
I have that on my driver side also.
Old Oct 4, 2008 | 09:02 AM
The passenger side is completely closed/sealed... is it supposed to be like this on the driver side or is this abnormal wear?
Old Oct 4, 2008 | 12:54 PM
Rubn1out4GudLuk's Avatar
I too have the same undone seam on the driver's side while the passenger side is not. I would also like to know if this is normal...wtf?
Old Oct 4, 2008 | 02:12 PM
Lubricating the pivot points solved my top hesitating to go down... I went to the dealer and showed a service manager the seam. Unfortunately, there were no other s2k's on the lot to reference. We looked at the spot further and from what we could tell there was no actual hole going into the cabin. It almost looks like it's supposed to be this way... it's just odd I never noticed it before The dealer said to watch it and if it gets bigger to let them know.
Come on fellow s2k owners
Old Oct 4, 2008 | 04:22 PM
trapper's Avatar
The top is sealed tight at that point on both sides on my 2004 S.
Old Oct 4, 2008 | 04:26 PM
Vanishing Point's Avatar
No wear mark as yet on my '07, but since purchasing the hardtop I leave the soft top down for extended periods of time.
Old Oct 4, 2008 | 05:03 PM
CatDada's Avatar
I had a similar issue; except mine was on the passenger side. But get this... it developed day one on a top that was a replacement for the original. The original was replaced under warranty when I noticed it was developing the too familiar wear holes in the top corners--apparently from rubbing of the rear most support bar. The dealer sent me to a local upholstery shop for install of the replacement. Upon noticing what looked to be seam seperation, the dealer told me the same thing, "to keep an eye on it." That didn't sit well with me, however. So I returned to the installer and asked for their advice. What he did to ease my mind? He took the lower corners of the top (where the seam looked to be seperating) away from the frame and applied a patch (glued) using part of the old top to the underside, covering the seems. This served to reinforce the seem area. Then he returned everything to its original position. So far, so good--its been more than a year and a half ago.
Old Oct 4, 2008 | 06:24 PM
S2KAYYY's Avatar
my passenger side is sealed while my drivers side isn't its been like that for awhile now. i hardly put my top down so im assuming this is normal i wouldn't worry about it only if it gets worse which i doubt it...
by the way i have an 07 with 31,000 miles
rizzllzahid
Apr 13, 2019 04:50 AM
wsteun
Dec 9, 2013 03:08 PM
thewiseboatmaker
Oct 13, 2010 09:02 AM
