Plastic Window tint
Old Nov 7, 2008 | 09:34 PM
RL428's Avatar
Default Plastic Window tint
So are s2000's with plastic window's pretty much screwed when it comes to window tint? It gets so freakin hot in the car without tint (texas), i'd just tint the sides but I'm afraid that would end up looking really goofy. I hate the look of non-tinted windows but again, the rear window is pretty big and I don't know about just doing the front two.
Old Nov 7, 2008 | 10:51 PM
Just Guy's Avatar
You can get plastic static cling tint, no glue required. It makes the plastic window look much better as it goes on the outside of the window. Do a search, there are lots of threads on it.
Old Nov 8, 2008 | 07:35 AM
8BALL's Avatar
and the application is simple too as you tint the outside of the window. Have had mine tinted for nearly 7 years and needed to retint it only once.
Old Nov 8, 2008 | 05:14 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Where do you buy that static cling ???
Old Nov 9, 2008 | 07:57 PM
RL428's Avatar
I just put on the static tint omg what a nightmare the edges were impossible to cut properly, there's gotta be another way
Old Nov 9, 2008 | 08:33 PM
duanet85's Avatar
walmart sells it, mines been on even after 140mph!
Old Nov 10, 2008 | 07:14 PM
8BALL's Avatar
Building a template is the way to go. Tape some aluninum foil together to cover the entire window and edge. Rub a dull point alng the edges. Cut to size and you'll probably need to refit a couple of times as well. Should make it pretty eay the next time.
Old Nov 11, 2008 | 05:33 PM
Vinsfeld's Avatar
Does the static cling stay on well when you open/close the soft top?
Old Nov 11, 2008 | 07:41 PM
duanet85's Avatar
i'v personally had no probs with mine
Old Nov 12, 2008 | 11:19 AM
chrilleg's Avatar
Do you guys know if there is a company that sell this thing in Europe, maybe even Sweden
