Door Frozen Shut
Old Mar 6, 2009 | 02:16 AM
russellhq's Avatar
Default Door Frozen Shut
During the last couple days of frost and snow, I've had real problems with the drivers door.
The deadlock action appears to be frozen on and as such, I can't open the door!
I had to wiggle the lock switch inside the car a few times (it was jammed) before I broke the ice and freed up the mechanism.
Anyone else had this problem before
I've also somehow managed to switch around the lock switch action! When the switch is flush, the door is locked and when the switch is proud the door is open. The opposite of the passenger door switch
Old Mar 6, 2009 | 03:16 AM
agent's Avatar
We had some freaky weather here (dense fog @ -5C) and i had the exact same problem. luckily passneger door worked. What i did is closed off all vents except the one that points to the driver's door, turned on the heater at max and drove like that. Then i spread a little bit of lock deice solution on the key and used the key to open and close the lock several times. After that the lock started working again.
Old Mar 6, 2009 | 04:12 AM
s2konroids's Avatar
Yes i have had it before, i always just get in the passenger side after 5mins it free's off, but what also helps is greasing the seals around the door.
Old Mar 6, 2009 | 06:36 AM
PJD's Avatar
PJD
Yeah I had this the other morning too, and also clambered accross the console from the passenger side.
Ah, gonna grease my HT seals next week so will do all the door seals also cheers Ajs
Old Mar 6, 2009 | 07:47 AM
azzurri's Avatar
yip same prob with drivers door thank god,nearside door ok.let car heat up for about 15 mins and it should be ok.
lunar_s2k
Sep 8, 2013 09:04 AM
britsportscars
Apr 20, 2012 09:55 AM
esracer
Aug 2, 2006 05:45 AM
hondaboy82
Mar 30, 2005 06:06 AM
wing
Nov 27, 2003 05:17 PM
