central locking not working :(
hi
ive bought an 01 s2k and my central locking doesnt work.
when i use the remote to lock/unlock the car, both doors open and shut without an issue.
now when i get inside my car and lock my door, i notice that the passenger door does not lock.
but if i press the lock button on my remote, magically both doors lock...
any idea what could be the issue?
ive taken the inside door skins off and havnt not found any loose wires.
any suggestions would be appreciated.
thanks
thanks
actually for mines, if i lock the driver's door, the passenger locks as well too. but it won't unlock both doors if i unlock the driver's door. maybe you should try leaving the door cap off and then locking the driver's side door to visually see if there is anything impeding the locking of the door. it might not be a loose wire thing but a mechanical thing.
then only issue is when i manually lock the drivers door, the passenger door does not lock (im led to believe that the passenger door should lock too if i manually lock the driver's door)
any thoughts?
thanks guys
well the fact that the passenger door locks and unlocks via the remote, leads me to believe that the motor is fine.
maybe the problem does not exist with the passenger door itself?
obviously there is a trigger from the drivers door to tell the passenger door to lock when the drivers lock is pressed from the inside??
