Leaving the S Garaged for 4 months
Old Mar 19, 2009 | 03:28 AM
MC_BLADE's Avatar
Default Leaving the S Garaged for 4 months
Right as per title I'm Out the country for 4 months, so the S will be sitting in the garage.
I'm going to have it serviced before I go (3 months early). Unfortuanatly I do not have power in the garage so no battery conditioner can be used. So should I disconect the battery or not?
Anything else I should do?
Old Mar 19, 2009 | 03:40 AM
eho's Avatar
eho
- Park in a garage
- Leave handbrake OFF
- Get car on axle stand
- Disconnect battery
- Make sure you are low on petrol in the tank (some say petrol do goes off if not used)
- Car cover
- Pump the tyres to a higher psi (maybe 35psi?)
Old Mar 19, 2009 | 03:41 AM
ian_6301's Avatar
Up on axle stands, handbrake off.
Battery up to you - a trade off between the alarm being available vs the battery dying.
Or... Get a trusted oppo to "exercise" it for you once a fortnight (but still no handbrake).
Old Mar 19, 2009 | 04:10 AM
MC_BLADE's Avatar
I was looking for a tyre cradle or similar as the garage is a bit tight to get in an the put the car on stands inside.
Old Mar 19, 2009 | 04:15 AM
PaulF's Avatar
I use an OptiMate charger (Clicky) rather than disconnecting the battery. It cycles the battery to mimic normal usage, so is actually better for the battery than disconnecting it; and allows the alarm to still be used.
Old Mar 19, 2009 | 04:23 AM
tomkbucks's Avatar
lend to me i will take good care of it
Old Mar 19, 2009 | 04:29 AM
jakesalter's Avatar
Which would be great if the OP had power to his garage!
I have however, seen a solar powered battery condition... probably just a crappy gimmick though tbh.
Old Mar 19, 2009 | 04:45 AM
S2000Si's Avatar
I have a solar powered conditioner (
Old Mar 19, 2009 | 04:54 AM
PaulF's Avatar
Oops, good point, well made
Old Mar 19, 2009 | 05:12 AM
E4RTH WORM JIM's Avatar
I was told the opposite.
Fill it to the brim. Stops moisture/condensation forming in the fuel tank.
