switching to fullrace updated new ?'s
Waiting on my heatshield now. Cleaning up engine bay a bit where are you guys tucking your harness that's on the fire wall? I also discovered my turbo blanket won't fit inbetween the motor mount and .82 hot side of my turbo. Which means I'll be opting for something thinner.
Originally Posted by freshs2k,Sep 20 2009, 03:58 PM
I want to know if ill have fitment issues with my 35r .82 hotside and .70 coldside to the motor mount and will I need to notch the frame? What kind of power will I be lookin at with the stock compression pump gas with water meth
depending on how much boost, what compression and how conservative/aggressive you want to run the car, you'll see 500whp+ on either pump or race gas.
15psi with water meth stock compression. I made 440whp with the pfab log mani and 38mm wg. The only thing ill be changing to is a 44mm wastegate and FR mani. Is there a lot of heat issues from the mani that some exhaust wrap can't fix? Should I worry about the motor mount?
I made 415whp 300ft/lbs at 18 psi with the log and made 425whp 270ft/lbs at 11psi with the FR. At 18Psi dropping to 16 at redline i made 475whp and 370ft/lbs.
your gonna have heat issues with the full race manifold. relocation of batter and control box is highly recommended. your gonna need a turbo blanket and a heat shield for the manifold. that manifold generates some serious heat under that hood. Serious heat...
