Backup switch (reverse light switch)
Old Apr 15, 2010 | 02:07 PM
aresk3b's Avatar
Default Backup switch (reverse light switch)
My backup lights do not light up when reverse gear is in.
Light bulbs, under dash fuses are ok.
I need to check continuity on the switch on the transmission.
The honda manual says the transmission needs to be lowered to swap it.
Is there a trick, way, method to change the switch without loosing up the whole transmission.
thank you.
Old Apr 15, 2010 | 07:03 PM
aresk3b's Avatar
Old Apr 15, 2010 | 09:39 PM
Stealth Operator's Avatar
I would use a voltmeter to first measure if there is electrical current on the wires before attempting to drop the transmission to fix your reverse lights. Sounds to me, it's shorting out somewhere.
Old Apr 16, 2010 | 08:43 AM
aresk3b's Avatar
thanx
Old Apr 17, 2010 | 05:35 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
There is alot of incorrect info in the book. I hope this is one of those cases.
something tells me you can just get under the car and swap it in 5 minutes...I'll check it out...
Old Apr 17, 2010 | 07:26 AM
SpitfireS's Avatar
The manual does not tell you to drop the trans.
edit: well... actually.... it kinda does.....
Not really drop as in: drop the subframe but you have to tilt & lower it.
It does show this fancy tool #1 though.
With the proper tools it looks like to be a 5 min job
Old Apr 18, 2010 | 12:34 PM
aresk3b's Avatar
I have the honda repair manual 00-03 s2000
this is what showed and scared me
Thanx billmanand SpitfireS.
Old Apr 18, 2010 | 12:52 PM
RedY2KS2k's Avatar
The special tool looks like an ordinary crowfoot wrench. Open end wrench with a 3/8" square drive to fit on an extension. Available at Sears or many other tool sources. I don't know what size it is, however.
Added link to Google search results with pictures:
http://www.google.com/search?client=firefo...G=Google+Search
gtman
Mar 23, 2018 12:09 AM
match417
Sep 16, 2015 10:22 PM
dundeelad02GT
Jul 15, 2009 10:50 AM
b0mbrman
Mar 19, 2005 10:49 PM
ahurst
Jun 4, 2003 09:15 AM
