OEM oil pressure sensor pinout on AEM
Old 06-08-2010, 06:44 PM
Spoolin's Avatar
Default OEM oil pressure sensor pinout on AEM
Hey guys,
I am trying to get my stock oil pressure sensor to read on the AEM but need to know what pinout its hooked to in the wiring. This way, I can turn that pinout on in the AEM to be able to log oil pressure. Does anyone know what pinout that its hooked up to?
Old 06-08-2010, 06:47 PM
RAIN H8R's Avatar
Hmm, this would be nice to do. But is the stock sensor capable of doing accurate readings of even high oil pressure?
Old 06-08-2010, 06:53 PM
Spoolin's Avatar
I'm not too sure. I was speaking with Ya about it earlier today and he mentioned doing it but didnt know what pinout it was,
Old 06-08-2010, 07:06 PM
siadam's Avatar
I didn't think the stock sensor offered any resolution for that?
Keep us posted!!
Old 06-08-2010, 07:07 PM
RAIN H8R's Avatar
Im sure its in the Honda manual, give me a second here
On a quick search I found this...
http://www.innovatemotorsports.com/resourc...Honda_S2000.php
Old 06-08-2010, 07:09 PM
Slows2k's Avatar
Not possible.
The VTEC pressure switch is a on/off input, it is not a pressure sensor.
The idiot light pressure switch is a on/off input to the cluster only, not the PCM.
Old 06-08-2010, 07:15 PM
Spoolin's Avatar
It is just a one wire sensor so I dont even know if it can be used to read all across the board on oil pressure. It may only be for low oil pressure warnings and not be able to read anything else. Does anone know about the stock oil pressure sensor?
Old 06-08-2010, 07:16 PM
RAIN H8R's Avatar
"The idiot light pressure switch is a on/off input to the cluster only, not the PCM. "
He's correct...
Old 06-08-2010, 07:17 PM
TRBOKEV's Avatar
Correct. I added a aem copper sensor and used the adr14 pin out. (I think that's where I have it)
Old 06-08-2010, 07:19 PM
RAIN H8R's Avatar
Good idea. Where is a good and CHEAP place to buy the AEM sensors? I might do fuel and oil pressure, and do an oil temperature sensor.
Quick Reply: OEM oil pressure sensor pinout on AEM
