not an s2k but still f20c! what do ya think?
Old Aug 27, 2010 | 11:09 AM
mnr vortx f20c's Avatar
Default not an s2k but still f20c! what do ya think?
got the f20c motor,box,diff,steering,clocks and modded prop into my mnr chassis and it fits under the bonnet (just) with no mods! what do you guys think it will go like? and a couple of q's. the car i a fully caged lotus 7 style kit car,discs all round,prm cai intake,4-1 silencer, 600kg's,s2k diff,clocks,switch gear and steeing. 13" caterham r500 wheels
1; steering arm runs tight to side of motor meaning there is only just enough room to get the oil filter in,wihout the standard oil cooler. do i need an oil cooler with this motor as its not going to be under tha same load as an 's' its only 600kg's and air flow is high due to completely open engine bay (i will put a large scoop in bonnet)
2; i am running 205/60/13 yoko a048's with standard diff. how will this affect gearing, and top speed?
3; where is s2k speed sensor/pickup as i will need to alter the clocks to compensate for the 13's? is there an easy way to do this?
4;how do i upload pics for you to view? i have a few on my pc but am struggling to upload!
Old Aug 27, 2010 | 11:19 AM
BSM139's Avatar
UK Moderator
Here is a guide to uploading photos.
Moved to the correct forum
Bharat
Old Aug 27, 2010 | 11:36 AM
Dembo's Avatar
I think it'll be really slow.
Speed sensor is in the gearbox, and JDMs and people with different final drives use a speed converter chip between that and the clocks. So you need to work out the difference between 205/60/13 and 245/40/17 and find an appropriate converter. Obviously you're going to have lower gearing and lower top speed.
Please upload some pics.
Old Aug 27, 2010 | 12:17 PM
the car is a bit more 'complete' than in these pisc as it was a while ago when these were taken!
Old Aug 27, 2010 | 12:20 PM
loftust's Avatar
That chassis wouldn't look out of place in a game of Kerplunk
Old Aug 27, 2010 | 12:23 PM
B0ZWELL's Avatar
use this web site to work out rolling radius
may be worth fitting an oil cooler with an small accusump and remote oil filter. high cornering speeds may cause oil surgewith a standard sump.
accusump link (just so you can see what they are there will be other sellers) . these will even give you oil pressure before you start the engine.
Old Aug 27, 2010 | 12:25 PM
could be worse, it could be a really bright colour
Old Aug 27, 2010 | 12:28 PM
bozwell, why do i need an accusump when the standard road car does not? this will be a road only car and not a track car so cant imagine oil surge being a major problem! do they do a sump baffle plate fir the standard sump?
Old Aug 27, 2010 | 12:29 PM
B0ZWELL's Avatar
oh and ther is some nutter fitting a F20c into a Honda S600 don't know where he got that idea from? . there is also someone on here trying to do the same with a S800 but i can't remember who it was
and these look really handy for mocking up exhaust manifolds (from above linked thread)
Old Aug 27, 2010 | 12:31 PM
B0ZWELL's Avatar
just have a look at how many threads are started "my engine rattles/gone bang" etc
