Bogging Down
I have 04 s2k with about 69,000 miles I have it for about a year now and I just started noticing that in low rpm my car bogs alot my car is stock! only when it hits vtec thats when the car starts moving at its best...Is this every s2k or only mine? could it be that I need a tune up or something? I change the oil every 2500 miles please help
Let's see...bogging on a S2000 with 69K that all you've done is change the oil:
-change the air filter
-clean the entire fuel system (including IAC valve and throttle body/plate);use 93 octane top tier fuel
-check the spark plugs
-change PCV valve
-turn the air conditioner off
After you fix the bogging problem:
-change the tranny fluid
-change the diff fluid
-bleed the clutch
-bleed the brakes
-wash and wax your car
-go for a drive and enjoy yourself!
-change PCV valve
-bleed the clutch
-bleed the brakes
^^ I like your list. As soon as i bought my s2k:
1.) changed PCV
2.) Checked plugs
3.) changed tranny fluid
4.) changed diff fluid
5.) bled clutch
6.) changed oil
7.) wash/wax
lol. She runs like a champ. Got it with 43.6k and now it's at 58.6k
1.) changed PCV
2.) Checked plugs
5.) bled clutch
6.) changed oil
7.) wash/wax
