Sponsor S2000 Engine and S2000 Drivetrain Deals Sponsor deals on S2000 engine and S2000 drivetrain products
**Mishimoto Radiators and more!**
Old Dec 30, 2010 | 01:59 PM
Kami Speed's Avatar
Default **Mishimoto Radiators and more!**
Honda S2000 Performance Aluminum Radiator, 2000-2009 (Standard & X-Line)
Upgrade your stock S2000 radiator with a Mishimoto performance aluminum radiator to maximize cooling efficiency, boost engine functions and protect your car from overheating. Whether you use your Honda as a daily driver or take it to the track a Mishimoto aluminum radiator will most importantly lower engine temperatures while enhancing the overall performance and lifetime of your vehicles engine. The Mishimoto Honda S2000 radiator features a lightweight dual core, 100% brazed aluminum, and polished end tanks. Every Mishimoto performance aluminum radiator is a direct OEM fit, making installation effortless with no cutting or modification required. All Mishimoto radiators come with a Mishimoto high pressure 1.3 bar radiator cap and a great warranty. Also be sure to check out the S2000 silicone hose kit, for even greater cooling efficiency.
Silicone hose kit
Mishimoto silicone Honda S2000 radiator hose kits are made with a dual layer combining high grade silicone and heat-resistant embedded fibers to provide efficient heat reduction and increased pressure tolerance, all with an OEM replacement fit! Perfect for your Honda S2000.
Performance Aluminum Fan Shroud Kit
The Mishimoto Honda S2000 aluminum fan shroud kit will considerably improve engine cooling functions and the overall performance of your vehicle. All Mishimoto fan shrouds are significantly lighter than standard fan shrouds, and are a direct OEM fit. A Mishimoto fan shroud will effectively drive out heat from the engine bay while delivering a significant amount of cool air directly to your S2000 aluminum radiator. At the same time the fan shroud serves another very important purpose; securing the fan blades in place, which otherwise could potentially damage other essential components in your engine.
Racing Thermostat, 2000-2009
The Mishimoto racing thermostat for the 2000-2009 Honda S2000 will promote greater cooling efficiency throughout your engine. The Mishimoto racing thermostat will significantly lower high engine temperature produced by modified and upgraded turbo applications. Once the engine is fully warmed up the Mishimoto racing thermostat will open up at a lower temperature than standard thermostats, also allowing the coolant to flow through the engine sooner thus reducing and maintaining cooler engine temperatures. Mishimoto Thermostat Activates at 60 C
OEM Thermostat Activates at 78 C
Honda S2000 Air Diversion Plate 2000-2009
The Mishimoto Honda S2000 Air Diversion Plate is not only intended to enhance the aesthetic appeal of your engine, but will incomparably reduce your radiator’s coolant temperature. All Mishimoto air diversion plates are constructed of 5052 aluminum and are available in several finishes. Choose from a natural brushed matte or an anodized glossy black or blue to enhance the look and style of your Honda's engine bay.
Mishimoto Radiator Stay, Black - Honda Civic, Integra, Accord, S2000
Keep your radiator in place with the Mishimoto radiator stay. Made of all-aluminum it is 40 grams lighter than your stock OEM radiator stay. The aesthetically appealing radiator stays will add a cleaner look to your engine.
All of mishimoto products come with Lifetime Warranty.
PM ME FOR THE S2KI PRICE GUYS!
Old Dec 31, 2010 | 10:11 AM
Tobisenpai's Avatar
pricing for radiator and silicone hose together n seperate pricings to 51041 iowa....thanks
Old Jan 3, 2011 | 02:41 AM
WaltsS2K's Avatar
Price for Radiator and fans/ fanshroud to 46107
Old Jan 3, 2011 | 11:48 AM
Kami Speed's Avatar
pmd guys!
Old Jan 5, 2011 | 01:30 PM
Kami Speed's Avatar
bumpp
Old Jan 7, 2011 | 09:31 AM
Kami Speed's Avatar
bumpp
Old Jan 10, 2011 | 10:24 AM
Kami Speed's Avatar
bumpppp
Old Jan 11, 2011 | 09:28 AM
Kami Speed's Avatar
bump;p
Old Jan 12, 2011 | 11:47 AM
Kami Speed's Avatar
bump!
Old Jan 14, 2011 | 01:36 PM
Kami Speed's Avatar
bump!@
