My heatsoak solution for PRM intake
Lol yeah it was definetly worth it since I find myself leaning on it a lot. When putting it on make sure you have the bolts to the ends really loose. The bar comes in 3 peices, and I went ahead and bolted on the ends to it before I installed it, and it wouldnt go on. I had to loosen those 2 bolts up holding the ends on and it barely made it slide onto the studs. Then once you got it on just tighten the bolt on each end, then put the 2 nuts onto the studs on each side.
fyi...
i had the prm intake and basically tightened the whole thing down with each coupler extended as far as possible. this put the mouth right up to the fender hole. i noted the temps via the intake temp value from the obd port. i had this intake for a couple years, so i know the temp fluctuations pretty well. later on, i replaced it with a comptech intake, with the enclosed box around the same area. .......and what do you know, the intake temp was very similar. within a few degrees before to after, sitting still, and on the highway.
so, my point is, your "heat soak" might not actually be as bad as you think it is. it might be mostly "in your head." did you check the intake temp via your obd port before and after? i'm guessing it's not that different. a bit better no doubt after your mod though. maybe a couple degrees?
That's very interesting. The only difference I can tell like I said before is the shuttering on warm days with the A/C on and when pushing the clutch going to a stop. I've had the PRM for a little while now and since it's been warmer, it started getting worse especially with the A/C on. Since i've done this it hasnt done it near as bad, and I daily drive mine and know how my S acts on a daily basis, so I know it's not all in my head, especially when the shuttering happens. I'm just happy most of that is gone, and hopefully will stay away once summer gets here.
also, fyi, comparing the comptech, which theoretically should be similar to your hose setup, and the plain prm, there should not be a large difference once your car gets moving. a lot of air moves through your engine bay while driving, and the negates most of the differences you found while idling. for example, while at a light, the temps are ~50-70deg c. but while on the freeway, temps will be ~32-45 degs (winter vs summer) while driving on the freeway. the freeway temps are more consistent, and do not really vary between prm vs comptech. however, while idling, there seems to be a little more variation, but i could not say which one was better.
anyway, bottom line, i'm glad it helped your car be more stable, but not so sure you actually have more hp from your mod. but that just goes to show the prm intake is pretty darn good, despite what one would assume.
I'm looking to get a PRM as well, but worried about heat soak.
Mod, how has it been going with the hose?
Are you able to take some close-up pics on the hose-end towards the radiator as well?
SilverS2kF22C1
02-01-2012 11:33 PM
Jaded41
05-31-2002 09:59 AM
