differential or axle noise
Old Oct 7, 2011 | 04:06 PM
unlewser's Avatar
Default differential or axle noise
I was driving yesterday and I heard terrible grinding sounds at all speeds from the rear of the car.
I have a feeling it is the differential, but what is the best way to diagnose it. From what I've read; diff, axles, wheel bearings, transmission, and the drive shaft are all suspectable points.
I'm going to drain the diff later today and see if there are metal chunks in it. Any other advise?
Thanks in advance for the help.
heres a video. You can hear the sound near the end of the video the best. Kinda sounds like liquid and metal swishing around in there.
Old Oct 7, 2011 | 05:30 PM
Neuman04's Avatar
Dosent sound too pleasent. Sorry to say man. It seems too loud and deep to be coming from the axels or wheel bearing. It honestly sounds like something is clunking around. Almost like a bad bearing or something in the trans. Cant say for sure but im going with something in the trans.
Old Oct 8, 2011 | 06:51 AM
unlewser's Avatar
anyone else?
Old Oct 8, 2011 | 02:11 PM
unlewser's Avatar
Is this normal???
At 10mph in 1st gear, constant.
idle in 1st gear, speedo said 4mph. driver side doesnt spin and the just wheel twitches
and i didnt hear the sounds like the first video on the jack stands
Old Oct 8, 2011 | 05:07 PM
unlewser's Avatar
trying to get all the info i can out there. The driver side axle isnt spinning. Still not sure if this is normal for our diff.
Old Oct 9, 2011 | 07:10 AM
unlewser's Avatar
opinions?
Old Oct 9, 2011 | 11:36 AM
03Mongoose's Avatar
I don't know about the sounds, but don't worry about the wheels spinning/not spinning at different speeds with the car up on the jack stands. I freaked out 3 weeks ago after swapping motors and I ran the car up in the air with similar results. Once back on the ground the car was fine. I didn't have any weird transmission, differential, or axels sounds. Good luck.
Bill
Old Oct 9, 2011 | 01:37 PM
unlewser's Avatar
Thanks for the response. Was the axle/wheel twitching like in my clip?
Old Oct 14, 2011 | 08:57 AM
unlewser's Avatar
just for closure, the problem was fixed. Happened to be a bad driver side wheel bearing. First time I ever heard one that bad. I heard the normal sqeaking wheel bearing sound 6 months ago, so I tightened the axle nut and it went away. This must have been on the edge of total failure.
Old Oct 14, 2011 | 09:51 AM
jpark's Avatar
i heard that just tightening the axle nut will eventually create noises again. not sure though
polar2k
Jul 15, 2014 08:20 PM
Chris_D
Nov 15, 2013 09:02 AM
speakeasy2009
52
Jun 9, 2013 03:35 PM
RangOs2000
Aug 15, 2009 05:12 AM
xrapidx
Jan 23, 2009 10:06 PM
