New York - Upstate New York S2000 Owners All areas North of I-84 (Port Jervis to Putnam Lake) in New York State
Dash light out
Old Oct 16, 2011 | 07:24 PM
lolls's Avatar
Default Dash light out
I've noticed that the left side of my dash, where the radio controls are, is a little duller than the other side, where the hvac controls are. Is that normal? Also my MUTE button no longer illuminates at night. Now, is it difficult to pull the dash to change the mute bulb? If I do, is it worth to replace all of them? Any suggestions are welcomed! Thank you.
Old Oct 17, 2011 | 05:40 AM
jsenclosure's Avatar
it's not too bad, but i can deffinately see the stock stearing wheel making it more difficult. Mine was a little tricky even with the quick release wheel. You can use the directions from qube engineering, that's what i used. Bulbs are very easy to change once removed
Old Oct 17, 2011 | 06:23 AM
lolls's Avatar
Thanks, I'll check out there website. I'd love to switch them all out to white. I saw a dash like that on there website and liked it alot.
Old Oct 17, 2011 | 06:56 AM
Maksim's Avatar
Radio controls are supposed to be a lot dimmer than HVAC - it is a "feature". Does Mute illuminate during the day ?
Edit: Here's something https://www.s2ki.com/s2000/topic/601...ce+light+bulbs
Old Oct 17, 2011 | 03:58 PM
lolls's Avatar
No the mute is deff out..
Old Oct 17, 2011 | 05:24 PM
lolls's Avatar
and why is the dimmer bulbs in the radio control a " feature"?
Old Oct 18, 2011 | 05:41 AM
Maksim's Avatar
Honda spec'd dimmer light bulbs on the audio control side -I think it is supposed to be less distracting at night - since secondary audio controls are not considered that important.
Not sure if the "mute" light is a bulb - I thought it was an LED...
Old Oct 18, 2011 | 07:33 AM
lolls's Avatar
It has a bulb to illuminate it at night and another to illuminate green when u press it. I might attempt to change it.. The directions don't look to hard ...
TankWookie
May 2, 2015 10:49 AM
Snuggie
Oct 31, 2014 07:30 AM
leggy
Dec 20, 2009 01:27 AM
eddies2k
Apr 6, 2009 05:24 AM
gt489
Dec 28, 2005 03:55 PM
