New York - Metro New York S2000 Owners Owners in New York City, Long Island, New Jersey, Connecticut
P0122 CEL Code
Old Oct 31, 2011 | 07:03 PM
PUNCHIN-IT's Avatar
Default P0122 CEL Code
Hey Metro,
Sorry to post about this issue again, but its still unresolved and I could really use all the help I can get.
The problem is:
I swapped my car (2005 Drive by Cable) from turbocharged back to NA and now my car is throwing a P0122 Code (Throttle Position Sensor/Switch A Circuit Low Input). I swapped everything back in stages and at one point, I don't know how, but I had the car running on a NA setup (intake and exhaust) with the 550cc injectors and 255 walbro fuel pump. The car seeemed to run fine at that point. I know it was dumb, but I had the car running like that for a few days. Anyway, the problem arised the minute I changed my 550CC injectors to OEM injectors. At this point, the car currently has a K&N Short Ram Intake, Tanabe Aftermarket Exhaust, and 255 Walbro Fuel Pump.
All current symptoms relate to a TPS related problem:
Rough/Low Idle
Surging
Stalling
No/Little Acceleration
So far I have done the following to remedy the situation:
Tested 2 sets of OEM Injectors
Replaced TPS with new TPS (Currently Reads: .35@Idle and 4.5@WOT)
Cleaned all wire connections
Checked throttle cable tension
Checked all vacuums lines
I have no clue what the problem is. I feel like I have a bad ECU or throttle body.
I haven't driven my S for weeks now and I'm dying of stress. I also need to use the S to commute on somedays of the week so I'm caught in a really tough situation. Please, if anyone has any insight or help it would be much appreciated. Thanks in advance.
Old Nov 1, 2011 | 04:29 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
PMed...ill likely be up your way this week...
Old Nov 3, 2011 | 04:48 PM
PUNCHIN-IT's Avatar
It was a tough battle, but its finally over!!!
We narrowed it down and it turned out to be an o ring to the MAP sensor!
Thanks Billman, you are the best!
3 weeks of S2K withdrawal. I'M DRIVING THE S NON STOP MUAHAHAHAHA
Old Nov 3, 2011 | 08:06 PM
S~Factor's Avatar
Don't you hate that? All that headache for a stupid $2 item.
Old Nov 4, 2011 | 06:11 AM
PUNCHIN-IT's Avatar
^Seriously lol, smh
Old Nov 4, 2011 | 09:27 AM
S~Factor's Avatar
Was the O-ring missing, ripped, or just out of place?
Old Nov 5, 2011 | 09:55 PM
PUNCHIN-IT's Avatar
^It was missing...fell out when I moved MAP sensor back to stock location
Old Nov 6, 2011 | 05:26 AM
Reborn56's Avatar
good stuff
v10killer
Oct 6, 2022 02:32 PM
airintake0_0
Aug 16, 2013 11:19 AM
PUNCHIN-IT
Oct 21, 2011 02:37 PM
s2kbad
Feb 16, 2007 08:36 PM
scxtreme
Mar 29, 2005 04:18 PM
