tiny leak from above clutch
Old Dec 20, 2011 | 08:48 PM
trAP2's Avatar
Default tiny leak from above clutch
Hey guys today i was looking under the clutch for pretty much no reason lol. I noticed that one drop had seemed to form of the master cylinder. I have had no problems with the clutch at all. Is it normal for a tiny bit of fluid to get by there? here is a pic of it. Also i recently cleaned some of the fluid out using a pump.
Old Dec 20, 2011 | 09:08 PM
Round 3's Avatar
if its grease then yes, if its fluid then you will need to change your clutch master cylinder because it will eventually get worse and you don't want to get stuck anywhere once it does.
Old Dec 20, 2011 | 09:16 PM
trAP2's Avatar
there was one drop of what looked like brake fluid u can see it in the picture. i took the picture before wiping it off. is it possible that after time the grease got a little watery?
Old Dec 20, 2011 | 09:22 PM
lltysonll's Avatar
http://forums.s2kca.com/showthread.php?t=15696
http://forums.s2kca.com/showthread.php?t=12154
just bleed it first! I gravity bleed it easy job. Is your fluid dirty/low?
Old Dec 20, 2011 | 09:26 PM
trAP2's Avatar
the fluid is light brown. gonna wait to see if it leaks for sure before changing it out. This is the first time i noticed anything. Plus clutch feels great right now
Old Dec 20, 2011 | 09:31 PM
lltysonll's Avatar
When was the last time you changed the fluid? Might be that time to do so.
Old Dec 20, 2011 | 09:37 PM
trAP2's Avatar
i never fully changed it. I used a pump to get what was in the reservoir dumped in new dot 3 synthetic pumped the clutch 10 times then repeated the process 2 more times
Old Dec 21, 2011 | 10:23 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
95% of s2k CMCs leak.
Keep the fliud clean, the leak will stop.
Old Dec 21, 2011 | 11:24 PM
trAP2's Avatar
since i cleaned it off i havent seen anymore fluid but will monitor it closely. So it is accceptable to have alittle fluid come through there?
Old Dec 22, 2011 | 11:57 AM
crank's Avatar
yea !
