3mm Wheel Spacer
I need some 3mm wheel spacers for the front to avoid the wheel rubbing on the inside under full lock. I'm running 255 all around on 17x9 +63. So far I've only found one quality set- T1Rs. Although it doesn't say if it fits our front center bores. Does anyone know if these will work?
http://www.evasivemotorsports.com/Me...5250-T03-5H114
http://www.aj-racing.com/shop/produc...cat=478&page=1
The other set I found are the cheap ones on Ebay. Although I'm concerned about the quality as they look pretty flimsy. Anybody have these are recommend something else?
http://www.ebay.com/itm/JAPAN-KICS-3...#ht_4774wt_901
If you want quality spacers go here: http://www.wheeladapter.com/wheel_spacers.php
Custom made to your spec
http://www.ebay.com/itm/380399783183#ht_2377wt_1270
I bought those for the rear of mine. They worked great
If they dont have any listed for the front center bore size, email then i'm sure they can make them.
Why doesn't anyone use local machine shops?
I'm sure they can make them fit PERFECT and be of quality for no more then 50 bucks
Will take an experienced lathe operator about 30 min to make a set
