What material do you want for the flywheel?
Old Feb 6, 2012 | 07:27 PM
RoninS2k's Avatar
Default What material do you want for the flywheel?
He said there was a certain metal or grade something like that.
Also what is a good weight for street use.
Any recommendations for a streetable w/ OEM disk but act HD pp
Old Feb 7, 2012 | 04:54 AM
w00t692's Avatar
Chromoly steel is what most of the good ones are made of, pretty sure stock is iron though.
If you have an AP2 an AP1 flywheel would be an awesome upgrade. If you have an AP1 you're gonna need to get like an 8 lb flywheel since stock is 11 lbs.
Old Feb 7, 2012 | 05:30 AM
S2KPUDDYDAD's Avatar
Stock AP1 is 13.9/14 pounds not 11 pounds. The Comptech flywheel is steel and is around 10 pounds and a good choice for AP1.
Old Feb 7, 2012 | 09:13 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Correct on both.
DONT GET ALUMINUM
Old Feb 7, 2012 | 09:34 AM
MP2k's Avatar
Originally Posted by Billman250
Correct on both.
DONT GET ALUMINUM
Have you see any failures of AL flywheels on the S? I gotta admit I was a little nervous about putting one on this high reving engine but so far so good. I am looking to get an ACT prolite the next time around though.
Old Feb 7, 2012 | 02:23 PM
LeonV's Avatar
DONT GET ALUMINUM
What are the merits behind this recommendation?
Old Feb 7, 2012 | 04:42 PM
slipstream444's Avatar
Originally Posted by LeonV
Originally Posted by Billman250' timestamp='1328638434' post='21392158
DONT GET ALUMINUM
While aluminum is lightweight - it's prone to warpage, and billet aluminum is extremely weak when hot. A flywheel will get pretty hot. Aluminum does not deform elastically, and therefore will fail over time (micro-fractures) - it is cycled frequently as a flywheel. Additionally, any aluminum flywheel is typically 3-piece. The friction material has to be a steel alloy or iron and the ring gear typically is steel. Those are all dissimilar metals with different expansion characteristics. This is not optimal - especially attached to a high-revving motor.
Chromoly steel is significantly stronger than aluminum (almost twice as strong - depending on the specific alloy), is more rigid (a good thing for a flywheel), and much more durable than aluminum - while being relatively lightweight. It's probably the optimal performance flywheel material for a high revving engine.
Old Feb 7, 2012 | 05:00 PM
zeroptzero's Avatar
DONT GET ALUMINUM
while I haven't seen any reports of an aluminum fly failures on an S2000, it has happened on other vehicles, and when a flywheel falls apart it is very dangerous, the stored energy in a flywheel can do some serious damage given where it is located under the cabin. Chances of a failure may be low but I wouldn't risk it.
Old Feb 7, 2012 | 05:45 PM
RoninS2k's Avatar
How do you guys feel about
ACT streetlite FW
ACT HD PP
Oem clutch disk
Had a competition clutch stg2, but the clutch disk shattered on me and i dont know how i feel about that again.
Old Feb 7, 2012 | 07:59 PM
Billman250's Avatar
Top Answer: 1
ACT streetlite FW
ACT HD PP
Oem clutch disk
I THINK the streetlite is aluminum.
Get the Prolite its chromoly.
Good to go on the other parts.
