PTuning Install & Review - Unbiased & Packed w/ Pictures
nice man i have same kit no issues yet, have anymore pics of the oil cooler setup? i ordered oil cooler and some lines for the oilcooler, saved alot money doin myself then ordering their oilcooler kit. .
I know you and many others have had good reliability with the kit but as with anything I am skeptic until I see it for myself. However I do believe it will be as reliable or better than most other kits including superchargers, unfortunately only time will tell.
As for the spool, I did not find it to be any quicker than many of the cars that I have built/driven in the past. The spool it’s self was not much different than the bottom mount 5865 0.63 A/R or sidewinder 5857 0.63 A/R or 6262 0.63 A/R but I would say the transient response was better. Overall a better feel than anything but the Greddy in that respect. I am excited to get the car on the dyno and overlay the new and old curves versus all the cars I have on file included Greddy, Inline Pro, SOS, Vortech, Mase Kits……. I am anticipating that the spool with be similar to the Mase 6262 0.63 but hold torque longer through the upper RPM band.
I personally would probably be more interested in a GT28 for the track if I was going to use a turbo again.
Evan's is Etuning the car now and as soon as that is complete we will hit the dyno and double check the timing and fueling using a reliable wideband.
The coolant lines to the turbo started leaking at the turbo. Based on what I can tell from pulling off the lined the rubber was just too hot and melted in the banjo bolt regardless of the heat shielding. We did not have time to do this but I would recommend making new 5-10" steel leaders to move the rubber line away from the turbo.
Where can I buy those steel leaders that you mentioned above?
Thanks
