17x9 +22 Wheel
Im looking at getting some rpf 1's in 17x9 +22. My question is will i have to go hellaflush? Im going for a good flush look but not to the point of hella flush. Also im thinking of running 225 series tire, opionions? If any one has pictures of this setup or a simialr setup it would help me out.
Thanks
Thanks
Yep, prepare to be flushed.
9.5 +38 and the 8.5 +40 is as far as I went. This is more aggressive then the typical 9/8 +45 which is still quite a bit more aggressive then stock mind you. Anything under +38 and your camber will be all jacked and going through tires like crazy. +22 is ridiculous territory.
You can save yourself headache by going with this popular setup which requires a little bit of modification:
17x8 +45 225/45 front
17x9 +45 255/40 rear
Also check out this thread which could help answer questions.
https://www.s2ki.com/s2000/topic/797...1-thread-pt-2/
