Factory Oil Cooler Removal
Old Jun 1, 2012 | 09:32 AM
herecomesboost's Avatar
Default Factory Oil Cooler Removal
To those of you who have removed the factory, water based oil cooler, what are the thread sizes/pitch on the block? TIA
Old Jun 1, 2012 | 09:38 AM
redboost10's Avatar
M20 x 1.5
Old Jun 1, 2012 | 09:42 AM
Originally Posted by redboost10
M20 x 1.5
Thank you
Old Jun 1, 2012 | 09:57 AM
Is the fitting under the intake manifold the same M20 x 1.5?
Old Jun 14, 2012 | 07:05 AM
For those interested in deleting the factory oil cooler, the factory oil drain bolt for the 05 Subaru Impreza is M20 x 1.5:
http://www.carpartswholesale.com/v5/...900401oidrpl05
Old Jun 14, 2012 | 07:11 AM
liquidgsr's Avatar
Hey Kyle I am probably going to sell my oil relocation adapter for plugs into the place of the factory oil cooler. If I give it to you can you check it to see if its the right pitch for the block? Im not planning on taking my oil cooler off so I am going to get a new oil adapter.
Old Jun 14, 2012 | 07:25 AM
Nesar, can you post a pic? Are you talking about an adapter to delete the oil cooler (like the one that comes with the Inline Pro relocation kit). I believe the fitting is from the 99-00 Si. I will verify that and try to determine the thread size/pitch.
Old Jun 14, 2012 | 07:26 AM
Part number 13 in the pic:
http://www.hondaautomotiveparts.com/...NER+%28DOHC%29
Old Jun 14, 2012 | 07:46 AM
liquidgsr's Avatar
yeah, It deletes the oil cooler and plugs straight into the block. Its not a fitting you add. The one I got was a male fitting not a female fitting where you would add the stock fitting from a 99 SI if that makes sense. The adapter bolts straight into the block. I bought it from someone on here used as a full race oil relocation kit.
Old Jun 14, 2012 | 12:56 PM
camuman's Avatar
I think the shortened bolt is from a crv or accord. Been awhile since I did it but works perfect. Basically oem price but shorter to accommodate lack of oil cooler.
