5th Gear Problems!? Wtf
Old Aug 16, 2012 | 01:26 PM
SlideWayz's Avatar
Default 5th Gear Problems!? Wtf
Ok so all of a sudden my fifth gear acts like I'm trying to push it into gear through Mississippi gumbo mud! Doesn't grind and no other gears are acting up.
I've read that the reverse lockout solenoid could be the cause but shouldnt reverse be hard to go into as well if this was the case!?
Car only has 27k miles on it so abuse is not the cause. Anyone else had this problem, or know of anyone that has had problems with this? Thanks
Brandon, South Carolina
Old Aug 16, 2012 | 01:38 PM
SheDrivesIt's Avatar
Do you skip gears when you upshift? For example, do you wind out to third then drop it into 5th or 6th directly?
Old Aug 16, 2012 | 02:22 PM
SlideWayz's Avatar
Having 477s i Sometimes do, yea. But I don't slam em
Old Aug 16, 2012 | 04:50 PM
MM3Kwolik's Avatar
There's your problem..... you've most likely deformed the synchro sleeve/hub on the 5th gear side.....placing it in and out of 5th gear with the car off a bunch of times might help smooth it out for you again.... (it'll remove any of the burrs that have formed on the synchro hub/sleeve) So apparently abuse IS the cause...
Old Aug 16, 2012 | 05:19 PM
kerm1t's Avatar
lol. yea u dont want to jump gears man..
Old Aug 16, 2012 | 05:22 PM
Carbon Blue's Avatar
there is your answer, its been documented that you shouldnt skip shift an s2k, it leads to a 5th gear lockout.
Old Aug 16, 2012 | 06:16 PM
SlideWayz's Avatar
Yea after I posted I found an old thread of this issue. Never heard of this before and never had problems with my last S but didn't jo around gears that much either. The 477s require lots of shifting around town.. Dang. Wish I read that earlier.
[/quote]
There's your problem..... you've most likely deformed the synchro sleeve/hub on the 5th gear side.....placing it in and out of 5th gear with the car off a bunch of times might help smooth it out for you again.... (it'll remove any of the burrs that have formed on the synchro hub/sleeve. So apparently abuse IS the cause...
[/quote]
I wouldn't say ABUSE as much as negligence. Lol Doh!
Old Aug 16, 2012 | 06:42 PM
MM3Kwolik's Avatar
Try what I said, and be sure to change your fluid after doing it.....it should smoothen things out a bit for you. (oh...it helps to have the tranny at operating temps before shifting in and out with the car off)
Old Aug 18, 2012 | 05:12 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I posted the fix for this years ago. Can possibly be cured in minutes. Search my posts damage is on the 6th gear collar.
Old Aug 18, 2012 | 05:14 AM
Billman250's Avatar
Top Answer: 1
No need to change fluid or have trans warm.
