delete
Old Oct 11, 2012 | 10:36 PM
Mr Ak's Avatar
Default delete
delete
Old Oct 12, 2012 | 03:34 AM
S2kAndTheAnt's Avatar
As I said before.... Bleed from the firewall.
Old Oct 12, 2012 | 03:24 PM
Mr Ak's Avatar
i tried that many times. first time without me knowing there wasn't any thermostat in the car. i was getting a bit of heat into the cabin. then when i realized that the car was running way too cold. i put in the thermostat. and as i said above, it just overflows the funnel and then overheats.
i even tried the little nipple near both heater hoses on the block, and also jacking the front of the car up to the sky, with the firewall method.
Old Oct 12, 2012 | 03:35 PM
The firewall is what worked for me when I had my Jenvey ITBs which ran into the same issues. If you really need the coolant bleed port, perhaps you should reach out to a fabricator, maybe they can fab up a bleed port for you.
Old Oct 12, 2012 | 03:48 PM
Mr Ak's Avatar
im not too worried about the port, as some kits dont have it as well. i have a feeling something else is going on. unless im getting massive amounts of air when i have the thermostat in place.
Old Oct 14, 2012 | 10:10 AM
kial007's Avatar
I had the same problem with my hondata gasket. It takes a while to bleed but not that big of a deal. Open the firewall bleeder and leave the rad cap off and let it burp. If your car gets hot, turn it off. It will take a long time but its not difficult.
Old Oct 15, 2012 | 11:51 AM
rrounds's Avatar
It looks like you could drill and tap the intake for a bleeder.
ROD
Old Oct 21, 2012 | 05:20 AM
bug man nrg's Avatar
this is not a flaw it is to hard to cast this hole in the manifold i do Jenvey set up's and a small thing like this is not that bad
Old Oct 21, 2012 | 05:27 PM
ninekallday's Avatar
I filled that hole with epoxy and have never had an issue while running my Kinslers.
Old Oct 21, 2012 | 10:13 PM
chris_barry's Avatar
You could drill and tap a hole for a 1/16 NPT plug ( like a fat taper grub screw) and remove that to bleed from that point.
If there is enough room, drill/tap a 1/8 NPT hole and use one of these.
https://www.pegasusautoracing.com/pr...asp?RecID=5210
