f22c re-sleeved
Old 03-08-2016, 03:23 PM
dgixxer25252's Avatar
Default f22c re-sleeved
I am in Tampa and I need to know where I can take my block to get sleeved in Florida. I want to avoid the shipping costs associated with shipping out of state. I am Willing to travel within the state or GA...thanks guys
Old 03-09-2016, 05:39 AM
JUSTINTHECOASTIE's Avatar
LHT Performance 7273441800 call and ask for John, I believe they use golden eagle sleeves, your choice of open or closed deck.
Old 03-09-2016, 05:46 AM
I spoke to John and he made it seem like they don't sleeve blocks...told me to call around some machine shops but no one in Tampa sounds very experienced with our blocks...
Does LHT in fact re sleeve blocks?
Old 03-09-2016, 06:24 AM
They ship it out to Golden Eagle in CA. Try Realstreet Performance if John is unable to help you, they are in Orlando however
Old 03-09-2016, 06:34 AM
Ok will do...thanks
Old 03-09-2016, 11:16 AM
Just an FYI, realstreet in Orlando doesn't do any machine work
Old 03-10-2016, 04:29 AM
trackHERO's Avatar
Most shops around dont do there own machining. Most shops send out. There is a shop called Engine Lab that does good work. Ask for Rocket. He is the owner and an avid racer and very knowledgeable.
Old 03-10-2016, 05:50 AM
I will call them today...thanks!
Old 03-18-2016, 02:41 PM
gsx2004's Avatar
Mesa Balancing in Miami
305-884-5368
Speak to Laz
really good work and has experience sleeving f20-f22 blocks
Old 03-22-2016, 09:07 AM
S000M's Avatar
If you're still looking for re-sleeved block? I have one sitting in my garage. The place that did mine is:
Mayor's Head & Block
5100 E 19th Lane
Hialeah, FL (Miami)
Osvaldo (Ozzi) Mayor
305-769-9354
He did my 2003 F20 a couple years ago and it ran fine until I spun a connecting rod bearing running the track at Sebring. I tore it down and sleeves are fine but decided to replace engine with a low mileage 2005 F22 rather than rebuild and replace pistons/rods/bearings. (Guy was parting out his perfectly fine car). I might consider selling it complete with crank shaft and new seals (when re-sleeved). Also timing chain assembly, pulleys, etc still assembled and ready to go. Crank is fine. I also have an unshaven completely rebuilt, never used, cylinder head assembly that I had Mayor's build and reassemble while I was replacing engine just in case I needed it. I live in Pembroke Pines, FL off of I-75.
Anyway, good luck with it?
control_freak
07-14-2010 07:53 PM
David_T
04-23-2009 05:46 PM
myblaks2k
09-13-2008 01:59 PM
Blackx2
03-23-2008 06:29 PM
Quick Reply: f22c re-sleeved
