Help installing rick's radio door gauges
Old 09-24-2004, 04:42 PM
KINGKHAN's Avatar
Default Help installing rick's radio door gauges
I bought a used Rick's radio door gauges off someone who ended up selling their S. I didnt get any instructions, and right now I'm kinda at a loss on the install.
I have the radio door gauges with boost(psi), A/F gauge, trans. temp., and fuel press.(psi). I also received the sending units.
The question I have is, are there any instructions out there for them, any site I can download instructions, or anyone who has installed them and may have instructions kicking around, or give me some kind of direction in installing them.
I was going to contact Rick's but thought I'd try here first, might be able to get some sort of instructions quicker.
Any help would be appreciated.
Thanks
Old 09-24-2004, 05:36 PM
fltsfshr's Avatar
Received 1,057 Likes on 540 Posts
Go look on Ricks website, he used to post all the the directions for things he sells on there. If you don't see it there look at the kind of gauges they are and go to their site. There should be an installation download there.
There are also some threads with pics in the forums on here that can help
good luck
fltsfshr
Old 09-24-2004, 05:40 PM
KINGKHAN's Avatar
Rick's doesnt have the instructions on their site and I took your advice, found out the make of the gauges, Nordskog, They have some help on their site, but would like to hear from someone who has actually installed the gauges.
Thanks for you help.
Old 09-25-2004, 01:49 PM
Stratocaster's Avatar
Digital gauge radio door assembly
Installation instructions
Tools/supplies needed:[LIST][*] Wire stripper[*] Wire cutter[*] Spade crimper[*] 26mm deep socket (these usually require a 1/2 socket drive) for attaching oil filter block adapter[*] 10 mm socket (for various bolts providing ground connections in the engine bay[*] Socket wrench[*] Small adjustable wrench[*] Assorted metric wrenches[*] Philips and slotted screwdrivers[*] Transmission fluid to replace drained fluid when transmission drain plug with sensor is attached[*] Oil to replace oil drained when block adapter is attached[*] Oil filter wrench or other appropriate tools to remove and attach oil filter[*] Black electrical tape[*] 1/8
Old 09-25-2004, 03:15 PM
xviper's Avatar
This thread just got technical, so moving to the "Technical" section.
Old 09-25-2004, 06:29 PM
KINGKHAN's Avatar
Thanks for the info Stratocaster, these instructions along with the ones I got off the Nordskog cleared up alot of my concerns.
jtj
04-30-2013 07:22 AM
1Fast99Si
02-04-2007 05:34 PM
KingAir
08-07-2006 01:45 PM
Headchef
04-17-2006 12:36 PM
Quick Reply: Help installing rick's radio door gauges
