DIY brake Bleeding
Old Apr 18, 2007 | 01:00 PM
20thStrube's Avatar
Default DIY brake Bleeding
What is the bleeding order for an 05 S? I saw a post listing Driver F, Passenger F, PR, DR for an 00-01, is it still the same for an 05?
I'm used to doing the one furthest from the Master cylinder, then working your way towards it.
Old Apr 18, 2007 | 03:16 PM
globallyoff's Avatar
Still the same. I have a new Helm's manual and an MY05. I did mine last week after HPDE course.
Old Apr 18, 2007 | 03:45 PM
silvers2k01's Avatar
Agreed
Old Apr 22, 2007 | 09:12 AM
s2krazy01's Avatar
Instead of starting a new thread, I'll just piggy-back on this one.
I want to replace my brake fluid with ATE, but I don't know what needs to be done. I was told that I'll need to flush the entire system, which will require about 2 gallons of fluid. Can I do this flush myself? Because I also read to never empty the reservoir.
Another general question: When you bleed your brakes you are replacing a portion of the fluid, right? What purpose does that serve if the majority of your fluid goes unchanged? Won't the old mix with the new?
Old Apr 22, 2007 | 10:17 AM
SpitfireS's Avatar
s2krazy01 Posted on Apr 22 2007, 06:12 PM
The procedure is described very well in the stickies on top of UTH.
Straingly enough.. it's this post
(yeah.. I went back to the future... or simular)
2 gallons!!
Thats 7 liters!
You would have enough..
IMO a complete flush can be done with 1/2 - 1 liter just to be safe.
Depending on your wrenching skills.
If the level gets too low you're introducing air into the system = bad.
IMO only a small bit of fluid inside the ABS pump will not be refreshed but will mix with the old as soon as ABS comes into play.
Old Apr 22, 2007 | 03:14 PM
s2krazy01's Avatar
Could you please provide the link? I can't find it anywhere...
Old Apr 22, 2007 | 05:22 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
EDIT:
I have revised this procedure that is detailed in the rest of this thread.
Please go here for the new procedure:
https://www.s2ki.com/s2000/topic/995...eding-revised/
Old Apr 22, 2007 | 08:16 PM
s2krazy01's Avatar
Thanks Bill! So this is a one-man procedure? No bleeder tools or pumping the pedal? Sorry to ask so many questions, but I've never done this before. I need to know every single detail.
Old Apr 22, 2007 | 11:22 PM
SpitfireS's Avatar
Billman250 Posted on Apr 23 2007, 02:22 AM
Start with the right front bleeder. Attach a clear hose, and let it gravity bleed till it turns blue.
Repeat for the remaining wheels.
Gravity is your friend
Maybe this post should be in the stickies?
Oh.. well.. maybe when the new forum is online.
Old Apr 23, 2007 | 01:00 AM
zpeed's Avatar
Billman250: Do you recomment any speed bleeder? or just clear hose and gravity?
Thank you.
