DIY brake Bleeding
Old Dec 14, 2012 | 06:57 PM
  #221
Wydget's Avatar
I just did this a few days ago. The rear passenger took FOREVER! Littleraly at least an hour. Then I opened the valve a little more and it finished within another half hour. Got back into the car and the pedal was brick like. Until I turned on the car, then it softened a bit. It was definitely firmer than I remember. But then again, I don't believe the S has had the Luis change in at least 70K miles.
Old Dec 14, 2012 | 08:43 PM
  #222
obsess2k'ed's Avatar
I felt mine soften too, so I tried Billman's overnight pedal trick... wedge a board or something of the right length (we used a toilet plunger handle) such that the brake pedal is firmly pressed in and then leave it sitting overnight. Be sure to pull the fuse for the brake lights or disconnect your battery. The next day my pedal was brick-like again and has stayed that way ever since.
Old Dec 15, 2012 | 03:30 AM
  #223
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I have revised the procedure...going to lock this thread and start fresh.
Please go here for the new procedure and to post reviews:
https://www.s2ki.com/s2000/topic/995...eding-revised/
Old Dec 15, 2012 | 08:14 AM
  #224
s2w0w's Avatar
Active Streak: 60 Days
Originally Posted by Billman250
i'm going to do a revision on the brake fluid change. My diy stuff is sometimes flawed, because I talk to everyone like they are a mechanic.
Looking forward to the revision Billman
skool u
Nov 27, 2009 08:51 AM
samsam5886
Nov 21, 2008 04:23 PM
owenxguo
Apr 7, 2005 09:02 PM
Sev
Apr 29, 2002 04:37 AM
