howto check if Mugen intake is authentic
Old 08-21-2014, 07:27 AM
BVE
BVE's Avatar
Default howto check if Mugen intake is authentic
Hi guys,
How can I check if a Mugen intake is the real deal? Are there markings (probably) and where should they be? Also, do they run their own brand of air filter or do they use somebody else's?
thanks.
Old 08-26-2014, 01:31 PM
DougEFresh's Avatar
It's a 2x2 weave, uses it's own filter (can get knn replacement one, color is different), comes with mounting hardware that mounts to crossmember and radiator support. Most fakes will not have the mounts that bolt on to radiator support.
Old 08-30-2014, 10:55 PM
nos4you's Avatar
Can Mugen intakes be installed/uninstalled without removing the bumper?
I know the air diverted has to be removed but mine is already removed.
Old 09-01-2014, 07:41 PM
DougEFresh's Avatar
Yes
Old 09-19-2015, 07:21 PM
zeroptzero's Avatar
Received 3,373 Likes on 2,452 Posts
Mugen intake is dry carbon, it looks quite a bit different than wet carbon fake parts out there. You really need to see one in person to know it though, Mugen should have a proper decal on it, you can buy Mugen decals but not really like the one that comes on the authentic Mugen piece. Mugen uses an AFE filter with part number on it, you can't buy the filter from AFE so fake parts will have a non-AFE filter.
Old 09-25-2015, 01:52 PM
Chris_Lum's Avatar
Mugen uses a K&N filter. If you look carefully, you can see "K&N" on the left side. Also, it's the usual red/purple K&N color.
Old 09-25-2015, 04:49 PM
zeroptzero's Avatar
Oh I didn't realize they were using K&N filters now. I've had two Mugen S2000 intakes and both have AFE air filters. My AFE Mugen filter is the red colour because I use the K&N cleaning and oiling kit.
Old 10-13-2015, 07:26 PM
Site Moderator
Manga_Spawn's Avatar
The dry carbon is the easiest way to tell the difference. All the reps I have seen have been wet carbon meaning it has a gloss coat to it and the weave is also a tighter weave pattern where the mugen is thicker. Not sure that makes sense. The real one has a metal bracket the reps have a carbon bracket. The real ones have holes drilled in the front to mount to the rad support he reps have indents but aren't drilled and don't include the hardware to mount to the rad support.
Old 03-26-2016, 04:21 PM
Mugen_is_best's Avatar
Mine came with a K&N filter. I'm guessing it depends on which generation of which intake you purchased.
Old 03-26-2016, 08:00 PM
zeroptzero's Avatar
Yes AFE is no longer producing filters for Mugen, they are K&N now, so the AFE equipped intakes would be from prior years.
Quick Reply: howto check if Mugen intake is authentic
