Car jerking while decelerating
Old 09-12-2014, 02:28 PM
S2kPowa's Avatar
Default Car jerking while decelerating
Recently I Notice my car started to jerk while in in any gear
Let's say I accelerate in 5th gear to 4k rpm and let go of gas car starts to jerk while I'm still in gear it stops once I put it in nutural . You can also hear engine sounds changing
Any Idea what this might be
My car is boosted but not fully tuned
I can only accelerate to 5k after that car cuts off falls on its face as vtec did not engage on dono so tuner set vtec at 5 K to diagnose the issue
I drove car like this for 8 months with out any issues. Now I have this jerking issue while decelerating
Please help
Old 09-12-2014, 03:09 PM
baZurk's Avatar
You drove your s2000 with a half completed tune for 8 months?
Old 09-12-2014, 03:16 PM
S2kPowa's Avatar
Yeah . There is nothing wrong with engine just did compression test 3 days ago I got 245 on all cylinders
It is safe to drive it it just won't get in vtec for some reason and as this is my daily I had no choice
I
And I ran out of options testing wise as what it might be
Vtec solenoid is getting 14v oil pressure is normal
Old 09-12-2014, 03:21 PM
Jin_SK's Avatar
Soooo is there a plan to GET it fully tuned? Why is it taking 8 MONTHS? Seems kind of pointless to be asking about drivability issues if the tuner isn't done with the car yet.
Old 09-12-2014, 03:26 PM
S2kPowa's Avatar
Yes of course I'm planning to get fully tuned just got to figure out what is the shit issue with vtec not engaging
BUT that's not why I posted about
I get vtec fixed once I got my bwm out of the shop which has been sitting there for 4 months
Old 09-12-2014, 03:30 PM
S2kPowa's Avatar
Also I have another issue when I was putting gauge into a fuel rail I took everything off fuel rail and my fuel would spray randomly out of fuel regulator hole with great pressure even tho car was off
Old 09-12-2014, 06:21 PM
baZurk's Avatar
The fuel pump turns on when the ignition is turned on, car does not have to be running. Also, get your car tuned.
Old 09-13-2014, 05:41 AM
S2kPowa's Avatar
Nothing was on. My keys were in my pocket..... When I released pressure from fuel rail it spayed fuel 3 more times in 10 min pressure was so great that fuel went from fuel regular hole and hit open hood so fuel sprayed like 1 feet..
Old 09-13-2014, 07:37 AM
baZurk's Avatar
Is your fuel pump hard wired to your battery? Fuel pressure in the rail means the pump was on.
Old 09-13-2014, 09:43 AM
sohc_mshue's Avatar
Sounds like decel fuel cut is not working.
Quick Reply: Car jerking while decelerating
