Fuel system for 1000 whp
Yeah, you may be right. 3 340's would be a bit better if I can get them to fit. May have my machinist buddy see if he can come up with a mount for 3 pumps on the dual hanger to replace the one on it.
1 450 can support 600whp no problem, so I would think 2 should be good for at least 1200whp if you look at it that way. You would have a really hard time fitting 3 pumps into the stock tank, the opening on the top is not big enough. The other problems other than that is the extra wiring and heating the fuel up even more. The walbro 450's barely fit into the oem tank, but you can get them in with a little finesse.
The Base Pressure and the Pumps ability to flow at high pressure makes a HUGEEEE difference...
I'd wait for the ID Screw Pumps and Controller...Run 100psi Base Pressure and be done with it...KISS.
I wouldn't try to put 3-450s in the tank...I'd just rock what you have until the better gear comes out.
