question regarding upgrading to NOVI 1220
Have anyone installed the new billet impellers for the paxton? I see superchargers rebuild have upgrade impellers for NOVI and provide more flow.
http://www.superchargerrebuild.com
So I I called Paxton and they will convert my 1220 to a 1200 oil fed. But they do not provide the oil fill and drain assembly. I have the Comptech 1220 and need to know where or how to I get the rest of the components to finish converting it to oil fed.
Assuming the feed is a 1/8" npt.
u get that to a AN style male that fits a companys oil feed kit, 18 or so inches I'm sure would work.
The return is probably a 2 bolt 1/2" npt female flange. So u get a 1/2" npt male to a 8 or 10 AN male then Russel fitting or equivalent and however u want to drain.
I know u probably wanna here first hand people which is understandable. Just trying to help. I helped a friend do this, although didn't record all the specs this was the jist.
iirc the feed kits r a -4AN
Thank you for Input. I found out Comptech brackets are similar to sos. Once I'm do e with my conversion and rebuild I'll post a tread. We have a lot of information scattered in hidden threads that require a lot of digging. I'll consolidate it once I'm done.
