staylor's turbo build
Old 06-06-2014, 08:11 AM
staylor725's Avatar
I know 19 psi is not safe on pump gas but it's only at 19psi with high boost switch on its normally at 16 psi. Fuse box it self no wires need to be extended but eps wires, horn, a/c pressure sensor, fans, and some grounds for head lights all needed to be extended lots of work.
Old 06-09-2014, 07:01 PM
3en
3en's Avatar
How's that idle and part throttle with the dw1300s?
Old 06-10-2014, 08:54 AM
staylor725's Avatar
Idle and part throttle are great. I asked my tuner if they were any good he said they work great, he only tuned a few cars with them, but I must say I had to buy a adjustable fuel pressure regulator to lower my base fuel pressure because it idled really bad and was stalling out all the time because my base fuel pressure was to high, but after installing aem regulator and a guage it was night and day difference.
Old 06-10-2014, 11:22 AM
biohazarde's Avatar
Nice build, What elevation and what kind of dyno? reason i ask is because on 91 pump, at 13psi i made 501whp, stock motor. I realize every car is different, but man thats a big difference, and scary with 19 psi pump!
Old 06-10-2014, 11:55 AM
staylor725's Avatar
Yea I was wondering the same thing different dyno different car idk, the elevation is 48 ft and dyno jet. Is yours ap1 or ap2 motor?
Old 06-10-2014, 12:58 PM
biohazarde's Avatar
dyno jet, ap2, and 5500 elevation
Old 06-10-2014, 01:55 PM
staylor725's Avatar
Yea ap2 makes more power, at 12 psi I was making 400.
Old 06-10-2014, 02:58 PM
spectacle's Avatar
Who tuned it?
Old 06-10-2014, 05:37 PM
staylor725's Avatar
Originally Posted by spectacle
Who tuned it?
induction performance alpha. Did u see that turbo drain flange I sent the link to on the post your turbo drain post ?
http://prlmotorsports.com/t3t4turboo...x#.U5TSOYm9LTo
Old 06-10-2014, 05:56 PM
03supers2k's Avatar
I'm running 18psi but I'm 9.1 compression. Maybe you should consider meth injection just to be safe.
Quick Reply: staylor's turbo build
