S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
The smell
Old 08-27-2016, 07:17 PM
879's Avatar
So I noticed the unpleasant smell when I was loading up my trunk to head to KC. So when I got back I did some detective work and found this.
Bear with me, I add some extras here.
Under the carpet a pool of water had formed.
So I did some sanding and picked up some paint over rust.
Sanded with a wire bristle brush
The paint I used
After the first coat of paint
Then I got a rubber under body coating that is water proof and applied 4 coats of that.
Next I tackled the vent, the foam gasket looked worn and dirty. Got some black RTV.
Then sprayed around it with the underbody coating
After the final coat of underbody coating.
Then I noticed quite a bit of moisture in the driver's tail light. Applied sealant and the next day applied heat.
Old 08-28-2016, 11:49 AM
zeroptzero's Avatar
Received 3,373 Likes on 2,452 Posts
Nice work. That's was one area that I mentioned in my earlier reply, it's a common source of leakage.
Nice work on the rear tails I had the same issue in the past, the sealant works well, I think some of the water gets into the lights from the trunk rain channels.
Old 08-28-2016, 05:03 PM
879's Avatar
Thank you, I hope it stops the large majority of water coming in. Still need to clean roof drains, but that's a project for next weekend. I will also need to do the silicon treatment on the passenger side as well to be safe.
Also forgot to mention I ordered a new tail light gasket.
Old 09-27-2016, 05:16 PM
omgitsoop's Avatar
The paint I used
Nice, now how about I pay you to do the same to my car
Old 10-24-2016, 04:21 PM
879's Avatar
The paint I used
Turns out it wasn't that bad to do, just time consuming.
So I forgot to include what I have been finding out in the past few weekends with this situation. Turns out the soft top is leaking. Solution? bought a hardtop
Neon001
09-06-2012 05:45 PM
Trent06
10-02-2010 06:02 AM
JSWhaler
01-13-2009 02:26 AM
ProV1
02-06-2007 09:25 AM
Quick Reply: The smell
