moldy, mildew, musty smell inside the cabin
Old Sep 30, 2010 | 11:37 AM
Trent06's Avatar
Default moldy, mildew, musty smell inside the cabin
i have a 2001 with 55k miles and i have this mildew like smell inside my car and it seems more prevalent when i leave the car parked inside my garage. i have pulled out the seats and completely oxi-cleaned my carpet. im wondering if the smell comes more from the seats or the soft-top just due to being old. any suggestions? i have plans of a hardtop and new seats in the future so if i find this to be the culprit, i might plan on purchasing quicker than i thought
Old Sep 30, 2010 | 11:42 AM
rnye's Avatar
Most likely related to your HVAC.
Change the cabin filter first. It gets more involved from there.
Old Sep 30, 2010 | 11:49 AM
Trent06's Avatar
changed the cabin filter about 3k miles ago
Old Sep 30, 2010 | 12:28 PM
elvir's Avatar
check if theres any water marks in the trunk area underneath the carpeting
Old Sep 30, 2010 | 12:32 PM
got.s2k's Avatar
Agreed, water in trunk is one possible cause. more info here:
https://www.s2ki.com/forums/index.ph...ic=465581&st=0
Old Oct 1, 2010 | 06:20 AM
Trent06's Avatar
Originally Posted by 2ndTimeAround,Sep 30 2010, 11:24 PM
It's most likely the HVAC system or you didn't dry the carpet properly when you cleaned it.
i was dealing with the smell long before i decided to clean the carpet. i thought the carpet might have been the problem but apparently its not.
Old Oct 1, 2010 | 06:33 AM
Saki GT's Avatar
Pop out the cabin air filter, start the car and AC system, and spray Lysol into the system where the cabin filter should be - that may help kill any mold or mildew in the ducts. Another option might be a dehumidifier in the garage.
Old Oct 1, 2010 | 08:00 AM
SeanSerino's Avatar
Water in the trunk is probably it. Pop out the tool tray and you'll probably see wetness.
Old Oct 1, 2010 | 08:59 AM
hippo and dog's Avatar
i've done this method before on my previous car and it worked!
although i did it a bit differently. i put the hvac to take in outside air at full blast and sprayed lysol on the interior air cabin intake vents.
maybe do both?
Old Oct 1, 2010 | 10:27 AM
EVAN&MONICA's Avatar
+1 for water in trunk most common problem even more likely since we just got into rainy season
