Anyone using smoked side markers?
My memory is different - I think the entire fixture came with mine.
Site Moderator
The entire fixture is just 1 piece. I'm not saying the lens pops out of anything you just take the oem one out and pop the new one on. Works the same weather it is OEM, ITR, Ricks etc. The part I am saying you don't need with the ones I linked is the wiring and the actual bulb fixture as that is already on the S2000.
I see - yes that is the way mine came. Installation takes five minute for both sides if you have done it before. There is a little trick - the clip has a small spring action, to remove you slide the entire thing toward the front a tiny bit and then lift the rear gently away from the body. Or is it the other way? If you look at your new part you will see which way to slide. To install you insert the rear and then gently push the front into the car which causes the spring clip to engage the body sheet metal. Easy.
MikeekiM
07-29-2015 04:35 AM
LcS2000
Member S2000 Classifieds and For Sale
02-21-2010 09:48 PM
