Question about OEM hardtop defrost harness
Old 03-28-2011, 02:55 PM
SIchodelic's Avatar
Default Question about OEM hardtop defrost harness
I bought a used hardtop + hardware from a MY07
My car is a MY05
When trying to connect the defrost wires, the plugs don't match. Do I have the wrong harness? jayhonda's PDF has 2 harnesses:
http://www.jayhondaaccessories.com/A...00/hardtop.pdf
a 3pin and a 4pin harness
Harness from the hardtop i bought:
OEM harness from behind my seat panel:
Also, what is the role of the hardtop strikers? Thanks for your help
Old 03-28-2011, 03:02 PM
vr0om's Avatar
You're missing another harness that connects the the wires from behind the seats to the harness on the side catcher and the harness on the hardtop itself. #3 on the picture from that link.
http://parts.sonshonda.com/showAssem...ssembly=284223
Old 03-28-2011, 03:09 PM
SIchodelic's Avatar
I believe I have that harness
the hardtop came with 2 separate harnesses. The one that is located on the OEM hardtop itself
another harness we removed from his side panel. the harness that goes through the little hole. That harness plug is picture #1 in my post
Old 03-28-2011, 03:23 PM
vr0om's Avatar
Yea it should be that harness that goes through the hole, it should have a rubber cap to protect the plug from dust and stuff. I don't understand what it wouldn't work because on my hardtop that is how all 3 plugs are connected.
Old 03-28-2011, 08:46 PM
RTZX9R's Avatar
Not sure on the wires. I replaced the original strikers with the hardtopvones to get rid of squeaks and rattles. They are different enough in design and now I can ride in 100% silence over any terrain. I also used the shin etsu lube on all the seals and recommend doing both. The HT strikersmalso work with the soft top.
I also bofughy the harness that goes between the HT cord (like a phone wire all curly) and the car. It was around 35 from majestic and plugged into my 04 perfectly. One end goes to the HT (with the molded end), while the other two plu g into the harness behind the seat. If they are not fitting they may be an earlier year?
Old 03-29-2011, 06:16 AM
Laker's Avatar
Can you please share any information on where you got your. "I also bofughy the harness that goes between the HT cord (like a phone wire all curly) and the car. It was around 35 from majestic and plugged into my 04 perfectly.
Old 03-29-2011, 04:59 PM
RTZX9R's Avatar
I bought my parts (new strikers and the harness) from Majestic Honda. www.hondaautomotiveparts.com
Put in your car info, and select the "Wire Harness (hardtop)" at the bottom of the drop-down list. You should get this image...
You need to buy #3 (honda part # 32204-S2A-010), which connects to the existing hardtop wire (#2) and the harness in the car.
Additionally, the instructions here explain it all in more detail... (STEP 6)
http://www.handa-accessories.com/s2000/s2k2top.pdf
I also bought the strikers and the rubber boots that go on the softtop frame. Sure most say they are not required, but for a few dollars I'll gladly trust Honda over the internet
Buy qty 2 of # 62 (honda part # 86270-S2A-902) and 2 of #82 (honda part 86445-S2A-000) the rubber spacer.
Old 03-30-2011, 12:19 AM
SIchodelic's Avatar
to the guy above me, thanks for the info. that's exactly what I was looking for
can you provide a link to the hardtop brushes? I tried to find it but couldn't
I was going to order through HTG for strikers, brushes, and the defrost harness
Old 03-31-2011, 02:21 PM
SIchodelic's Avatar
Thanks for the help guys
was able to order the missing hardtop pieces through a local dealership (hondapartscheap.com)
came out to about 140 whereas HTG wanted 200
Old 09-21-2011, 11:50 AM
passnu2's Avatar
did you keep this harness? I just got a used hardtop and found out that the harness I have must be for an AP1 or an older AP2. What you have listed matches the plug in my car.
Or if anyone has the harness for an 08 PM me please willing to trade my harness for the correct also if that helps out.
bruceski
11-20-2015 05:33 AM
jferazzi
07-25-2015 04:28 PM
BLACK EK
01-09-2013 12:21 PM
smithengineered1
01-31-2010 09:22 PM
Quick Reply: Question about OEM hardtop defrost harness
