Key broken off in ignition.
Long story short, S2000 involved in an accident, key broke off in ignition switch, unable to tun key or start car.
If you have a fix that will compromise security for all S2000 owners then please feel free to PM me.
Thanks in advance.
ps: No this was not my car, just trying to help a friend.
Thanks in advance.
Thanks for the help thus far.
The key snapped and piece of it is in the ignition? Tweezers or pliers maybe? Did it break clean off at the surface or is it wedged inside the tumbler?
Thanks again for all the PMs.
So I'm assuming the ignition switch is still in the ON position, correct? So before trying to pry key out, you'll need to turn ignition off, to tje position key is normally pulled out.
I suggest you try and use a small screwdriver or something for that. Obviously you want to make sure steering wheel is pulling against its stop. May have to have a second person hold wheel to alleviate pressure, while person 1 tries to turn off ignition.
Then dental picks. Harbor Freight has some cheap. You'll want tje ones with long skinny metal handles, not the ones with orange handles.
Originally Posted by s2000ellier
strong magnet?
