Shifter "sticks" in gear
Ive noticed fairly frequently that when trying to shift out of gear I have put a bit more effort than other times to get the shifter into neutral. It's never really stuck, but definitely not smooth. I'm planning on regressing the shifter this weekend and replacing the plastic nub on the bottom but I have never seen this specifically mentioned, anything else I should check or will the re-greasing likely cure it? Sometimes it's butter smooth as it should be and other times it "sticks" a bit.
Well that could very well be your issue. If there is air in the clutch line it will compress and may not fully disengage the clutch. That would result in difficulties getting it into and out of gear.
