New York - Metro New York S2000 Owners Owners in New York City, Long Island, New Jersey, Connecticut
Billman Motion S2000 Repair Thread IV
Old 10-24-2007, 06:52 PM
Billman250's Avatar
Received 1,253 Likes on 763 Posts
Arrow Billman Motion S2000 Repair Thread IV
<——Click on the “Billman250” and select Private Message to order the Billman GenX tensioner unit.
Ask about...
- "The once over, difference you can feel" service
- Billman Motion Generation-X Production S2000 Timing Chain Tensioner (see below for info)
- All phases of installs and mods
- 2018 XR custom fit chain tensioner
- transmission rebuilding, while you wait
- modified soft top latches
- Billman Motion rollbar mounting system, over 4 times the strength of original design, and no cutting of the body required
All pricing inquiries will be returned via PM....
Billman's Once Over:
Custom Valve adjustment, retainer inspection, & spark plug torque check
Air filter
cabin filter
oil change Mobil1 & PCX filter, or ck oil and filter torque
dif fluid change with Mobil1 75W90
trans fluid change with NEW Honda MTF
clutch fluid change, clutch adjust, and throttle adjust
brake fluid change with ATE Super Blue
spark plug replacement (Honda S2000 spec'd NGK's, not the ones you buy online)
Tire-saver toe-in adjustment, no alignment needed
Coolant flush
axle nut tsb
IAC rotary valve cleaning
dash removal and bulb replacement for audio, heater, and cluster
Loose 12V outlet fix
wiper inserts
topdown mod
AC mod (02-09)
soft-top anti-rip mod
soft-top anti-rip instruction
check brakes
inspect serp belt
air psi
general check-up
100k pulley inspection
motor mount inspection
camwheel bolt inspection
Priced individually, only services needed are done.
Billman Motion Generation X Modified S2000 TCT (Timing Chain Tensioner)
-3 years in the making...application tuned
-precision machined extended reach housing, restoring factory preload to factory spring rates
-Resets chain guide load to exact factory pressure, where it was when the engine was new
-restores TCT piston positioning in the TCT housing
-restores worm gear positioning in the piston and preload
-linear pressure: tightens as engine RPM increases
-anti-cavitation function: Oil inflow into the TCT is drawn off an internal machined ramp, just as you would pour a drink down the side of a glass. Eliminates air in the TCT, and piston retraction when oil pressure is low at idle.
-ease of install, no retracting bolt. Simply install and pull the pin
-lifetime guarantee, which includes personal technical support to your individual case.
Tensioner is only available via S2KI PM (personal message)
The Billman GenX TCT is based on years of research, using a broad range of chain guide operating depths worldwide. I have put my all my resources, passion, and heart into this one product. Each one is built and machined exclusively by myself, pressure tested, and is application tuned to provide perfect tension to the chain under all circumstances.
Under The Hood Forum discussion about the Billman GenX TCT with data charts:
https://www.s2ki.com/forums/&quot;https://www.s2ki.com/s2000/topic/1146144-billmans-tct/&quot;&quot;]Billman's TCT - S2KI Honda S2000 Forums
2020 Edition
The following 37 users liked this post by Billman250:
.Boston. (02-22-2022), 99MCoupe (07-05-2020), bhahlbeck (10-02-2017), Blue2ki (05-12-2021), Borka (05-06-2019), BostonMike (06-15-2023), BrosufStalin (09-17-2019), BStobie (06-23-2019), Charles Ibasco (04-03-2020), ChrisPNW (06-23-2019), Davide Rosendahl (05-22-2021), denzelycat (10-24-2022), dhl (10-18-2022), Dirtyharryhoudini (11-19-2023), ecobuster (01-12-2020), EleazarS2k (01-28-2022), Firewalker (09-07-2020), funat9000rpm (05-01-2018), Ghost001 (05-12-2022), Henry Abreu (09-06-2020), james2kap2 (12-28-2022), JamesB_22 (05-29-2020), Jayden Paul (05-23-2020), joegabriel (07-28-2022), justgold (01-20-2020), Jwit84 (11-18-2020), Kerry Earnhardt Jackson (03-28-2019), kgf3076 (11-19-2020), manchild83 (03-16-2020), Mike Legra (05-23-2020), monsteronedge (04-10-2021), pgeyleg (10-17-2022), QoookieMon (11-27-2022), S2KAndres11 (12-22-2019), S2kruben (01-28-2023), SCS2KAP1 (11-12-2023), yokuzuna (10-09-2019) and 32 others liked this post. (Show less...)
Old 10-24-2007, 07:02 PM
HiPER's Avatar
i just wanted to be the first post .... i am awaiting mine, nervous to see condition of retainers, and also nervous for the test drive
Old 10-24-2007, 07:04 PM
Davizzle's Avatar
wed!! i shot ya a pm
Old 10-24-2007, 07:40 PM
HJZ
HJZ's Avatar
Originally Posted by Billman250,Oct 24 2007, 09:52 PM
hjz...Lotus
I'll be a happy man if you can get me in one weekend sometime late Nov.. Probably want to do oil change, stainless steel lines/brake fluid, and whatever else there is
Fsf (09-29-2018)
Old 10-24-2007, 07:47 PM
Tel1sps's Avatar
l still need to be on your list....
Old 10-25-2007, 03:38 AM
daktruckie99's Avatar
Still on for the springtime Bill
Old 10-25-2007, 04:17 AM
Nate03's Avatar
Bill,
Will take what you can give me... and make it work.
Just out of town from 11/3-11/8 & 11/20-11/24
thnx
Nate
Old 10-25-2007, 04:39 AM
S2KNJ's Avatar
hey bill, keep me on the back burner, the invidea exhaust solved my mysterious engine noise... or at least i can't hear it any more. ;-)
Old 10-25-2007, 08:21 AM
s2knauer's Avatar
do you work on bikes, and could u possibly come to my house cause my bike isnt registered or insured?
and how much for a once over on the S
Old 10-25-2007, 09:02 AM
sleeper_s2k's Avatar
i'm still here! just outta the country..
Quick Reply: Billman Motion S2000 Repair Thread IV
