Sponsor S2000 Engine and S2000 Drivetrain Deals Sponsor deals on S2000 engine and S2000 drivetrain products
URGE Scavenger System Launch;
Old 02-03-2017, 07:58 AM
  #131
captnplnet's Avatar
The new single and dual exhausts are no longer being made by T1R? Is that correct?
Will the Scavenger mid pipe work with the T1R dual purchased directly from T1R or another vendor? I think my last question was probably covered in another Urge thread but after going through all 50+ pages over the past few days my brain is a bit scrambled.
captnplnet is offline
Old 02-03-2017, 02:35 PM
  #132
Sponsor
Urge's Avatar
Correct, we are making the new Dual and Singles locally. T1R made a great product but we had to buy in larger quantities that was appropriate for Group Buys.
Our new system we had more design input and were able to reduce weight by 40%, have rebuildable mufflers with slightly higher expenses.
Yes, our mid pipe will work with an existing T1R Dual.
__________________
Urge is offline
Old 02-03-2017, 11:57 PM
  #133
captnplnet's Avatar
Makes sense, especially with the overseas shipping. The new system look pretty nice. Any sound clips of the dual design?
Old 02-04-2017, 08:11 AM
  #134
Sponsor
Urge's Avatar
Not on the Duals yet as we will have production units by end of next week.
Our Prototypes were used for test fitting and waiting on a few other things for the shop car. The shop car has ITBs and 2.5L motor so it wont sound the same.
We will need some customer clips with Stock engines to post.
__________________
Urge is offline
Old 04-14-2017, 05:22 AM
  #135
Jpmelfi's Avatar
New exhaust looks nice, just not crazy about how it looks with the AP2 bumper. I wish they filled out the cut outs more. Is there any plan to offer oval tips?
Jpmelfi is offline
Old 04-14-2017, 07:24 AM
  #136
Sponsor
Urge's Avatar
We might be open to do a custom tip. Can you find the piping you want?
__________________
Urge is offline
Old 04-19-2017, 09:22 AM
  #137
Slagathore's Avatar
Does anyone have photos of the new duals at ground level for an AP2?
Slagathore is offline
Old 04-28-2017, 10:23 AM
  #138
turbo8765's Avatar
Originally Posted by Urge
43 Scavenger Mid Pipes Sold!!
OEM Motor; Gern Pipe vs Test Pipe vs Stock
260+ WHP 2.3L Built Motor; Gern Pipe Full Tune vs Gern Pipe Quick Tune vs Berk 70mm HFC Full Tune
Gern Pipe $1200
  • Patented Mid Pipe Designs produces more HP than a Test Pipe
  • Gernby Tuned Expansion Chamber that creates Scavenging Pulse from 3500 to 6500 RPM
  • Expansion Chamber reduces Drone from 3500 to 6500 RPM
  • Expansion Chamber also includes sound baffling on non STR versions
  • 2.5” Honda Header Flange, Connects w/ OEM and common aftermarket headers
  • 304 Stainless Steel Tubing
  • Integrated Hi Flow Catalytic Converter
  • 3" Flange Outlet
Mid Pipe Options
  1. URGE Spec; connect to URGE V2 Exhausts
  2. STR Spec; Expansion chamber opens with in 6” of OEM Cat, Quote from the September 2014 fastrack in response to letter #14037: "In regards to the location of non-OE catalytic converters the STAC considers the inlet to be the location where the expansion chamber begins. Additionally, there are currently no restrictions as to where the catalyst medium may be located within the assembly"
New Single & Dual Exhaust Offerings
  • 3" Inlet Flange
  • Ultra Light Weight Coast Fab Mufflers
  • Modular Design that can be repacked as needed
  • Single Mufflers are 3" ID for less restriction x 17" Long for improved sound suppression
  • Dual Mufflers are 2.5" ID x 12" Short to reduce weight
  • Dolphin Tips for further sound reduction
  • Reduced Weight from Previous Exhaust by >40%
Exhaust Options
  1. URGE Single V2; $600
  2. URGE Dual Muffler V2; $1100
  3. Make your own Exhaust System
  4. Weld into your current system
New Mufflers Ultralight & Rebuildable Mufflers
  • $300 to $350 MSRP each
  • Weigh less 2.5-3.5 lbs each!!
New Single Exhaust Option
New Dual Exhaust Available Now
20 ft-lbs at 5k revs with no tune!?!?
turbo8765 is offline
Old 04-28-2017, 03:00 PM
  #139
Sponsor
Urge's Avatar
The top graph shows Stock, Test Pipe with Tune and Gernpipe with Tune.
The bottom graph is a built motor and everything is tuned.
So all gains shown are tuned vs tuned. True gains of the part and not the part vs something else.
__________________
Urge is offline
Old 05-01-2017, 05:07 PM
  #140
sillyboybmxer's Avatar
Saw the single v2 in person finally. Looks tons better than the pics.
sillyboybmxer is offline
Quick Reply: URGE Scavenger System Launch;
