Guide to changing the clutch fluid?
Old 10-02-2011, 10:32 AM
s2konroids's Avatar
No worries Gary, it just threw me a bit.
Old 10-03-2011, 06:40 AM
eho
eho's Avatar
When you are changing the clutch fluid, you may need to manually pull the clutch pedal back up after pressing it. Cant remember why this is but only occurs on the clutch. Maybe something to do with the pressure? I am sure someone here can answer.
Old 10-03-2011, 12:35 PM
F3 ANG's Avatar
Just a small tip, try not to pump the old fluid through the system, if you can get hold of a syringe and suck the old fluid out of the reservoir first that way you won't be dragging any sediment or such through the cylinders. Ang
Old 10-03-2011, 01:45 PM
s2konroids's Avatar
Good tip
Old 10-03-2011, 01:51 PM
s2konroids's Avatar
I'm thinking now my brake bleed pipe will be to big for the clutch bleed screw, as i read its 8mm as opposed to 10mm for the brakes?
Old 10-04-2011, 01:30 PM
s2konroids's Avatar
Changed the clutch fluid and brake fluid today, very easy TBH dont know why i was making such a meal out of it .
Clutch fluid is still slighty dirty
Used 2x500ml bottles for the whole job.
jkelley
09-06-2013 04:50 PM
s2krazy01
07-02-2010 08:00 PM
danx
12-23-2009 09:24 PM
Jasonoff
03-23-2005 09:55 AM
Quick Reply: Guide to changing the clutch fluid?
