Leaking shock absorber
The B16 uses the same springs nut the shocks are adjustable for bump/rebound
Obviously they are about double the price so for track use.ok but Road.only perhaps not worth it..
I have koni yellows with eibach springs, I find them really good, they have adjustable damper settings which make it useful to stiffen up for the occasional track day. I have mine set in the middle and they are excellent for the road.
Good choice, I have been twitching on a set of these for a while now, I did tons of research on them and even spoke to the German guys on the Bilstein stand at the NEC back in January.
Let us know how you get on
I had the same set up on my last car but with OEM springs and heartily agree with Robin. I loved the set up, it was a significant improvement over the OEM compromise IMHO.
MREATWORK (06-04-2021)
Both the Koni Yellows and Bilsteins are highly rated. Both seem to have pros and cons.
Konis - have greater adjustability but not for ride height of I'm correct.
Bilsteins - no adjustable damping but can control ride height easily
With either set up - when replacing my existing shocks - which bolts and bushes am I likely to damage that will need replacing?
None with damper replacement..
But getting correct Geo after may be a problem if front camber & caster are not all free and adjustable
rear Toe adjustment & camber also, expensive to sort if not diy
<check before booking it in for full damper install>
That's my concern - I'm pretty sure my rears are seized.
Shall I go ahead stick the coilovers on and the then try and get an alignment done? Deal with any problems I find at that point?
Will it be driveable after putting on the coilovers and before an alignment?
UK Moderator
You can get the bolts checked for a few pounds. Do that first, and then decide what to do. Whereabouts do you live, perhaps someone can recommend a place to have that done?
Why do you think some of the rear bolts are seized?
