Greater impact on ride? Front or rear suspension?
Ride rates can really only be tuned for a specific situation. The engineers choose a target vehicle speed for the car to ride "flat," choose an expected weight distribution based on driver and anticipated passenger/cargo load, then choose the springs that will deliver a flat ride in those conditions. Any deviation from the "flat" speed or weight will throw things off and change the speed at which the car will ride flat (if at all). From what I've seen, your average Accord or Civic rides pretty flat at freeway speeds with just a driver.
That was my plan. I was thinking 450 because I am also running out of rear shock travel (limitations as you say). So right now I am 1" below stock but could go up to 3/4". Question... If I raise it up, won't that increase the effective wheel rate because of the roll lever arm?
I do expect you'll see an increase in subjective comfort by lowering the rear spring rates on the S2000, especially if you aren't changing valving.
snitm
04-08-2018 08:07 AM
hybridb18
08-05-2013 08:04 PM
biker1
03-10-2003 09:46 AM
